Car won't start
  • 1744 Views
Offline PG Bob
Car won't start
« on: June 11, 2016, 03:34:55 PM »
While driving the engine just quit.  All the indicator dash lights came on.  The engine cranks, I can smell gas, but no start.
Offline beagle..t
  • 1239
  • 16
Re: Car won't start
« Reply #1 on: June 11, 2016, 04:43:54 PM »
more info needed model, make, engine size, check engine light on cant help until we know these things
Offline PG Bob
Re: Car won't start
« Reply #2 on: June 16, 2016, 10:31:03 AM »
Sorry.  It's a 2000 tracker 4 door hardtop.  I couldn't find an engine size on it but according to google the hardtop only came in a 2.0 liter engine.
Re: Car won't start
« Reply #3 on: June 16, 2016, 12:12:49 PM »
Is the check engine light coming on when the ignition is switched on?
Do you have access to a code reader?
Have you checked to see what, if any codes are set?
The traditional troubleshooting methods are still applicable - do you have air, fuel & fire - and no, being able to smell gas does not count, that gas may not be where it needs to be - in the cylinder.
The 2.0 engines have been known to have cam position sensor issues - BUT - the sensors are more likely to fail when hot and work again after they cool down, rather than a sudden outright failure.
I'm not certain if you can see the cam through the oil filler - take a peep, and if you can, have someone crank the engine whilst you observe - does the cam turn?
Offline RideorDie
  • 52
Re: Car won't start
« Reply #4 on: June 23, 2016, 10:53:08 AM »
I am know wizz when it comes to anything but a toyota. Take a look at your fuze box under the hood. If it is fuel injected check to make sure that the efi fuze is not blown.
