Vitara Rear Suspension Question
  • 1 Replies
  • 1764 Views
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« on: September 24, 2005, 06:56:01 AM »
I am going to grind off the old suspension point on the bottom of the diff for the rear shocks and make up stronger/longer ones(so the shocks do not hit the diff and damage them).
Question is if I make the bracket shorter(the length it hands down from the diff) does that give me more or less travel when flexing across.
Hope I am making sense?
« Last Edit: September 24, 2005, 07:02:31 AM by suzukiboyoz »
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Re: Vitara Rear Suspension Question
« Reply #1 on: September 24, 2005, 02:07:16 PM »
Are you using longer shocks? With the Calmini kit the lower shock bracket should be ground back to give clearance for the shock. I would have thought it would be easier/simpler to move the top mounting rearwards a little to get clearance. Moving the mounting up should give a little more drop but you may have to lower the bumpstops to prevent the shock bottoming out.
