From 1.3 EFI to toyota 2000cc diesel
  • 1726 Views
Offline noman8ff
  • 17
« on: December 07, 2016, 10:47:45 AM »
I have this modified lwb 1.3 efi manual jimny and want to go for a diesel swap. Here in pakistan, we do not have the wv diesels and the only options available are the 1.8 1C or 2.0 2C toyota diesels. My question is that will there be any negative effect of engine weight on the overall drive especially in offroading in sand and slush as the diesels are a bit heavier. I believe the stock 1.3 is around 80/ 90 kgs where as the diesels are almost double the size.
  • 6589
Re: From 1.3 EFI to toyota 2000cc diesel
« Reply #1 on: December 09, 2016, 02:37:47 PM »
I'm afraid we don't see many smaller Toyota Diesels like that here in NA so our experience would be limited. (maybe some of the European ZWO know?) One thing I would caution on though is to be mindful of the RPM range of the diesel you select vs. the Suzuki engine... Be mindful not to install an engine that can not rev enough to get you good highway driving.
would you take pictures of your rig and share with us? I'd love to see it and see what kind of difference there are to what we have here?
Thanks and good luck with your swap! -Eric
« Reply #2 on: December 09, 2016, 03:45:13 PM »
On the plus side if you can find a 2wd transmission you can probably get a driveshaft made to bolt it up to the stock SJ-413 t-case.  It would make the swap a lot easier.
