X90: Are 33's Impossible?
  • 10 Replies
  • 7698 Views
Offline Uncivilized
  • 1469
    • Car Domain
« on: March 03, 2008, 05:10:00 PM »
A friend of mine just bought a 97 X90. He has access to 33" Boggers, and we're trying to figure out what we need to do to fit them. We have a 3" body lift, and 2" coil spacers we can use, but we don't think 5" will be enough. We're estimating we need about 7 or 8" total lift which leaves us short.
What have others done to run this size tire on an X90? We're not interested is frame stacking, or solid axle ideas, we want to keep it IFS, and we need to work with what we have... (coil spacers, body lift, welder & steel) We're leaning towards a frame chop, but don't want to do something we don't have to.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: X90: Are 33's Impossible?
« Reply #1 on: March 03, 2008, 05:45:58 PM »
The problem faced with installing larger tires on an X-90 is all the extra sheet metal around the wheelwells. You need 2" of lift and a little trimming just to fit 215's or 225's. Throwing on 3" of body lift in addition to 2" of suspension lift might get you 30's, 31's with some trimming. To fit 33's, I would imagine it would take a full 3" suspension, 3" body lift and more than slight trimming. I have a 98 X-90 running a Calmini 2" suspension kit and it's got 215/65's on it. I am planning on putting 215/75 BFG All-T's on it soon, but I think I am going to have to either add some small coil spacers or trim some more to get them to clear, especially up front.
Maybe some other people will have more useful info about it than me, but good luck with it and post pics! LOL!
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: March 03, 2008, 08:15:16 PM »
Get the 4 or 4.5" ZukiNation lift and make a 3" body lift. Maybe hack the fenders back a little while you're at it.
Offline Armour
  • 360
« Reply #3 on: March 03, 2008, 08:25:54 PM »
It can be done. I have a pic of one in the gallery under poser shots that a friend and I did. We did a 8" frame drop and 2" spring spacer in the front. In the rear is grand cherokee front springs which give 6" and 4" spacer. Lengthened the lower arms and remounted the stock upper.  It is on 33x12.50x15 in the pic. So it can be done. I am running the same set up in my trackick and it works great.
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline Digger
  • 1991
« Reply #4 on: March 03, 2008, 09:25:58 PM »
So basically 10" of lift to fit 33"s... :o
Offline Element
  • 1902
  • LillyKicker
« Reply #5 on: March 03, 2008, 09:32:24 PM »
do it right!!!
Drop 3 large and get the trail slayer!!!
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
« Reply #6 on: March 03, 2008, 11:27:54 PM »
do it right!!!
Actually that is a good Idea.
then it could look like this.
Or a Lil more fender trimming and you Could have this.
Offline Digger
  • 1991
« Reply #7 on: March 03, 2008, 11:50:59 PM »
That has to be one of the coolest X-90's Ive ever seen!(the second one) I love it!
Offline Armour
  • 360
« Reply #8 on: March 04, 2008, 04:18:44 PM »
do it right!!!
I am not saying that my way was better. I would do trail slayer also. I was my first build and didn't know if a would enjoy it and use it enough. I am not spending that kind of cash on something that is going to sit around. I will build another and it will be done differently. I was just giving some examples to answer the post.
Offline Element
  • 1902
  • LillyKicker
« Reply #9 on: March 04, 2008, 04:47:27 PM »
Hope I didn't offend, I am just impressed with what I have seen, I hope to live vicariously through others since I will never be able to afford it...
zUkTAH
U4WDA
Offline Armour
  • 360
« Reply #10 on: March 04, 2008, 06:57:34 PM »
No, none taken. I would build one like that in a second. I would work alot better then what I have now. But mine works for what I have been using it for. I didn't want to spend a fortune right off in case it wasn't for me. But i love it so I will drive this one for now and biuld another in the mean time. Well aleast that is the plan.LOL
