does anyone know were to get 4 Jeep XJ or TJ 2" coil spring spacers
  • 9 Replies
  • 1668 Views
Offline sidekick 4x4
  • 97
  • sidekick
i want to do this 3" body lift http://www.zuwharrie.com/content/view/11/27/1/0/
it says you need 4 Jeep XJ or TJ 2" coil spring spacers and im not sure if you really need them or its just to get a little suspension lift. so if any one knows were to get those or some thing that will do the same let me know.
« Last Edit: May 21, 2006, 09:08:07 PM by sidekick 4x4 »
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
The 2"inch coilspacers are for the suspinion lift (put on coils and raise the suspinion)
Offline magiccat
  • 98
  • 94 Sidekick 2.5 spacer lift 30x9.5 mt's
I got my coil spacers from Haws Strictly suzuki
I got 2.5 in. of lift front and back
sky manufacturing makes some;as does rocky road
Just remember to drop your front diff. if your going over 1.5 in.
your camber will be off also  \      /
I fit 30x9.5 fine they just rub the frame at lock both sides- if I had less backspaced wheels that would take care of that
heres a pic of my cv angles with no drop brackets
Offline locjaw
  • 2045
  • 22
talk to digger here on the board, he was making coil spacers for a while. they were inexpensive enough for me to buy a pair "for emergency" ;D
jason
Offline magiccat
  • 98
For the rear I've heard you could use honda accord springs that yield about 2 in of lift. That would be better than spacers. The front i'm not sure what you could use. Grand vitarra springs. Then you would have better flex and you wouldn't have to worry about loosing a rear spring at full flex.
Oh yeah the spacers I got from Hawks- I had to grind a lot of the inside of them for them to fit in the front. The front was a pain. The rear worked fine.
  • 97
  • sidekick
ok i looked at all those linkes and the only place that hade them was rocky road and they had only a 1 1/8 space and thats not much so if u guys could send me the link or some thing becase i dont see them on the other sites u guys are talking about
   Here's the Sky Manufacturing link.  1.5" spacers.
http://www.sky-manufacturing.com/
Offline magiccat
  • 98
http://www.hawksuzukiparts.com/ or try hawksstrictlysuzuki.com
he has coil spacer up to 3in. if you want. They come in pieces that fit together to your desired height.
  • 97
  • sidekick
do i go under the sidekick section bc i dont see it. either there not there or im blind and retared
Offline magiccat
  • 98
sorry, I don't think he has it listed on the web. ;D I live near merlin so I just picked them up from his shop. I would just give him a call or e-mail him. I know he has them though cause I got a set from him.
I just remembered I heard of guys of using shoppong cart wheels and that works fine. YOu want to do some late night scavenging and check it out and see if it works. Hope that helps.
