Fuel guage in reverse?
  • 10 Replies
  • 2718 Views
Offline costazukirica
  • 10
  • Llantas abajo!  Cielo arriba!
« on: July 04, 2005, 11:53:31 AM »
http://www.zukiworld.com/public_html/YaBBImages/huh.gif
Huh
The Samurai I just bought has a curious feature: the gas guage works in reverse (as the gas gets used the guage shows more gas in the tank - when full I am on Empty).  I suspect this is because the wires are reversed.  Question is, if that is the case, then does it matter where I reverse the wires?  IF that is NOT the case, then what is up?
Las llantas abajo, el cielo arriba, las chicas atras, la calle al frente, pase adelante!
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
Re: Fuel guage in reverse?
« Reply #1 on: July 04, 2005, 04:47:44 PM »
I have the same problem on my samurai too!
When I fill the tank it reads below empty. I reset the trip odometer, and as I put a hundred or so miles on, it will then show about a half tank. After it reaches the half tank mark, it will work correctly.
I don't think it will be wires mixed up, I am betting that it is a bad ground. I am not sure, it just where I will check first. If it is not a ground, I am leaning towards the fuel tank float. I have a spare tank just incase I need parts.
I have heard if your fuel gauge is stuck on E, that is a bad ground.
If your fuel gauge is stuck on F, that is a faulty gauge.
I haven't had time to fix mine yet, but I need to.
If you get your repaired, please post back to let us know what fixed it.  ;)
Offline locjaw
  • 2045
  • 22
« Reply #2 on: July 04, 2005, 05:14:07 PM »
mine does the same thing as the general zuklee but I have just gotten use to it  :-/ never ran out yet ::)
jason
Offline breadbox
  • 119
  • Me Like Doughnuts!!
« Reply #3 on: July 05, 2005, 05:04:52 AM »
Ha, Ha, Ha,  :D that is exactly what mine does, when it is full it reads evpty and when it gets to about 1/2 it starts working normal.  I just fill it back up when it gets to E the second time.
1.3 ltrs of FURRY!!!!!!
« Reply #4 on: July 05, 2005, 07:44:01 AM »
That's a fuel guage that's for
guys that spend more time
upsidedown   ;)
Offline Luvmyzuki
  • 247
  • ZukiWorld Rocks!!!
« Reply #5 on: July 05, 2005, 01:03:44 PM »
I had the same problem with mine too. I found it was a ground problem on the sending unit.  I cleaned up a bolt on the tank where it sendinding unit is mounted in the tank and rand a ground wire to the frame.  After that the gauge worked great again.
Jeff
Offline Natebert
  • 1098
« Reply #6 on: July 06, 2005, 03:48:01 AM »
You guys have it all wrong!
:D
E = 'enough' (gas)  You don't need anymore, keep on going.
F= 'fill' (it up)  You'll be pushing it home soon if you don't.
« Last Edit: July 06, 2005, 03:58:15 AM by natebert »
« Reply #7 on: July 06, 2005, 03:04:30 PM »
:D
I guess that means.
mine doesn't work right.
LOL ;D
Offline toolman21
  • 229
  • 89 Kick with 5" lift and 30's
« Reply #8 on: July 07, 2005, 12:51:24 PM »
Jeff
I see two wires going to the sending unit, I am assuming one is the ground, I didn't see "a" bolt, just a couple of bolts that mount it in the tank, are those the ones you are talking about?
How much (and where can you get) a sending unit anyway?
Toolman
Offline Luvmyzuki
  • 247
« Reply #9 on: July 07, 2005, 01:08:18 PM »
Yes the mounting bolts are what I grounded. The sending unit is groundd to the tank and as thigs rust and get dirty  ;D grounds seem to get lost.
I bought mine from the Dealer . I believe it was around $25-$30 bucks.  Even with the new sending unit I still had the problem until I cleaned up the sufaces and ran the ground wire to the mounting bolts.
  • 503
    • MOAB PICS
« Reply #10 on: July 07, 2005, 01:20:04 PM »
Thanks for the input!
I will try it soon.
I kinda thought it would be a bad ground.  ;)
