Fuel sending unit/fuel gauge problems
  • 5617 Views
Offline nutergav
  • 10
« on: November 06, 2005, 05:17:10 PM »
Gday all,
I'm having a problem with my fuel gauge.  I have just bought a 1993 Suzuki Sierra and when i fill up the tank the fuel gauge goes below the emty line.  Then as i use the petrol it comes back up to about the half tank mark before it goes down again.  This makes it very confusing for me.
How do i fix this problem?  Is it simple to fix?  What do i need to fix it?
If anyboby has any diagrams they would also be very helpfull to me.
Cheers all, Gavin
Offline Hill Billy
  • 10
Re: Fuel sending unit/fuel gauge problems
« Reply #1 on: November 06, 2005, 05:30:42 PM »
Usually the ground wire at the sending unit, common problem, may be broken but usually is just corroded.
James
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: November 06, 2005, 06:46:35 PM »
Do Trackers/Sidekicks/Escudos/etc do this and would it also possibly cause the fuel guage to stick to full?
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #3 on: November 07, 2005, 10:28:53 AM »
The wiring for the sending unit goes through a large junction plug located behind the left tail light. This plug junction is prone to corrosion and could cause the type of problem you are describing. There is also a ground junction in the same spot that you can check, too...
Offline bus_driver
  • 479
« Reply #4 on: November 07, 2005, 11:14:02 AM »
with my recent fuel pump experience listen to digger and chek very carefully in the harness.....!!!!!!!!!!
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline nutergav
  • 10
« Reply #5 on: December 26, 2005, 07:07:01 PM »
Can anyone tell me if the junction plug is located on the same side for the Australian suzuki?  And is the left hand side looking from the back or the front of the car.  I have had a look and was only ablo to find 1 wire coming from my sierra.  am i right in assuming this also carrys the earth back to the juction box or is it earthed from the sending unit to the tank itself?
Cheers, Gav
