gas tank lift
  • 7 Replies
  • 1754 Views
Offline trailtracker
  • 44
  • the fixing/modification is endless!
gas tank lift
« on: December 25, 2005, 12:59:26 PM »
i put a 3 1/4 inch body lift in, and have now decided  that i need a gas tank lift. am going to cut out my two rear crossmembers and weld in new ones as they are rusted, but what the heck am i supposed to do with these two solid metal lines? do i just need to buy new rubber to hook up to them or is there an easier way? thanks
Unsafe at any speed
  • 44
Re: gas tank lift
« Reply #1 on: December 25, 2005, 01:14:51 PM »
well i tried to post a picture but i guess its failed
« Last Edit: December 25, 2005, 01:18:59 PM by trailtracker »
Unsafe at any speed
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: gas tank lift
« Reply #2 on: December 25, 2005, 08:06:02 PM »
Its been a while since Ive done a gas tank lift but I am pretty sure I just bent them upward.
Mike
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: gas tank lift
« Reply #3 on: December 25, 2005, 11:33:46 PM »
where the metal fuel line bends out 90 degrees from the frame, bend back straight, so it is pointing staright up. the tank should be ableto be lifted and clear these lines. i then cut some fuel hose to the length needed, and put some metal clamps on the hoses to the tank.
  • 44
Re: gas tank lift
« Reply #4 on: December 26, 2005, 10:07:30 AM »
i was just worried that the metal 90's would kink from being bent.  has this happened to anyone?
Unsafe at any speed
Offline vitara-dave
  • 11
  • I love YaBB 1G - SP1!
Re: gas tank lift
« Reply #5 on: December 26, 2005, 10:41:16 AM »
I didn't do a thing with those lines and it fits fine.
mudfkr
Re: gas tank lift
« Reply #6 on: December 26, 2005, 12:55:01 PM »
I pulled as much of the steel pipe up threw the plastic clip that holds it to the chassis and then bent the end to about a 45 degree angle then replaced the hose with slightly longer ones just to make it easier to get them on.
  • 44
Re: gas tank lift
« Reply #7 on: December 26, 2005, 08:22:58 PM »
thanks you guys are very helpful
Unsafe at any speed
