"stop leak" in transer case and tranny?
  • 1066 Views
Offline museboy07
  • 641
« on: May 27, 2007, 12:43:35 PM »
Can I use this stuff to temporarily stop the leak till i get the time to rip it all apart?  If so...what exactly should i use?
Offline mrfuelish
  • 2862
Re: "stop leak" in transer case and tranny?
« Reply #1 on: May 27, 2007, 02:40:48 PM »
Is it the seals or the case halves? solivent will swell up the seals, the case bolts could be loose if leaking there, put some new gear oil in it. oh ya check your vents,make sure there not cloged,they should be the wobble type.
« Last Edit: May 27, 2007, 02:48:00 PM by mrfuelish »
Offline museboy07
  • 641
« Reply #2 on: May 27, 2007, 08:12:47 PM »
what vents are you talking about?
Offline mrfuelish
  • 2862
« Reply #3 on: May 27, 2007, 08:29:40 PM »
anything that has gear oil in it has a vent, if the vent gets cloged the thing will leak gear oil.
