Hagan widening set-up??Need left side axle stubs
hobgoblin
224
January 25, 2006, 04:13:42 PM »
Hey All,
Thinking about tring this out,I understand most of it,But can you use a 1/2 spacer on the passenger side axle.It's not going to be easy to find 3 left side drive axle stubs.Any body got one that they would sell??
Thanks Tom K.
brlj
512
6" Lift w/ 33x12.50 TSL Radials, Exoskeleton
Re: Hagan widening set-up??Need left side axle stubs
January 25, 2006, 04:23:30 PM »
Are you going to run the Toy cv's? If so you only need 1 extra plus its a lot stronger setup. I got tired of busting stock cv's and front spider gears so I went with the Toy cv's and Sammy diff upgrade. Itll save you money and hassle in the long run.
Bill
hobgoblin
224
January 25, 2006, 04:36:57 PM »
Ok Guys,
What Toyota axles?? Year make and model PLEASE!!Only thing I can think is |removethispart|@95 truck???I'm sure they are stronger.Will they bolt to the stock axle stubs??
Thanks Tom K.
Uncivilized
1469
Reply #3 on:
January 25, 2006, 06:20:37 PM »
What if your not changing the cv's - then could you use spacers? Or would longer bolts to accomidate for the spacers be a weak link?
37kicker
319
3
97 tracker 9inch front and rear on 40" pitbulls
Reply #4 on:
January 26, 2006, 05:36:42 PM »
what Bill is talking about is a toy axle conversion kit i have avalible. you use ifs toy axles instead of kick ones . stan
