Gears
Gears
inchaos10
162
Gears
July 18, 2010, 01:53:05 AM »
I have 90 geo trracker 3speed auto. 6" calmini lift, 33" pitbulls.. What would be the best gear to get for it. Will see some highway driveing so looking for an all around type gear. want to be able to cruz 75 with no problem would be great
FireCkrEd
246
3
Re: Gears
July 18, 2010, 08:21:26 AM »
Get the highest ratio you can get. In my 95 4 door I have toyota axles with 5.71's, 31's for tires and a manual trans and I have to get into 4th and sometimes 3rd to pull long hills. It will cruise all day at 70 in 5th gear at 4200 rpm till I get to the hills...
Ed
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
wildgoody
8134
67
Re: Gears
July 18, 2010, 08:39:33 AM »
How much do you have to spend? And how mechanical are you?
like are you comfortable rebuilding an engine or tearing apart an
auto trans valve body? Can you weld or have access to a friend that can?
I have gears for you, 5.83s but they aren't cheep or available these days
from the old suppliers, both ends have lockers setup in them and will correct
your gearing to a little lower than stock
inchaos10
162
Re: Gears
Reply #3 on:
July 18, 2010, 10:40:28 AM »
I have money to spend but trying to keep a budget. But i rather do it right the first time then waste money. Mechanicaly im pretty good, but i never dug into a transmission yet. Thats going to be the first thing i do when i get back from iraq. Have a tracker that i beat the snot out of and ready to make it bigger and better. and yes as in access to welder. What are you asking for them? what kind of lockers are in them?
wildgoody
8134
67
Re: Gears
Reply #4 on:
July 18, 2010, 12:12:42 PM »
The front is a Trail Tough 4 spider, and the rear is a Genuine Gear,
I want $1850 for the drop out setup with the lockers installed, and
considering they aren't available anymore that's not a bad deal all set
up with lockers ready to bolt in
inchaos10
162
Re: Gears
Reply #5 on:
July 19, 2010, 08:37:16 AM »
ohh yeah that too steep for my pockets. Would i be better off runing a 31" tire with the 5.12 gears.
wildgoody
8134
67
Re: Gears
Reply #6 on:
July 19, 2010, 10:36:41 AM »
Ya, I know, I put the money into them good parts, but the getting
it back is the problem.
I really want to switch over to the Undertaker from Trail Tough,
I wonder what they would give me for them
