Calmini 3" Lift w/1" coil spacer=CV Destruction
  • 30 Replies
  • 5904 Views
Offline skitime
  • 302
Re: Calmini 3" Lift w/1" coil spacer=CV Destruction
« Reply #30 on: February 10, 2009, 07:35:48 PM »
I measured the body of the strut before and its about 13 inches.  I will try removing the strut spacer.  Is the Calmini strut a stock Sidekick strut?  Can I get a replacement at Autozone?
I stock strut is the same size as a Calmini strut so that should be fine.  I have a pair of Calmini struts that I had on less than a month I could sell.  The Calmini strut is a stiffer strut than a stock strut.  If you are not using a heavy bumper the stock strut would be fine IMO
