Problems can't get rear driver side axle out !!
  • 12 Replies
  • 1697 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« on: April 10, 2005, 02:34:35 PM »
I GOT IT OUT YAY.
I also got the third member out YAY Again.
Now if I can find some better pictures than the ones in the lock rite manual I'll put the locker in.
Hey does anyone know if the driver side rear axle shaft is supposed to be harder to pull out than the passenger side,
Any tricks for getting it out I don't have a slide hammer.
Also could I unbolt the third member with the axle still in?
Would this cause any problems.
Also does anyone have the torque numbers for the internals of the third member.
I don't have it out yet but I looked through both chilton's and haynes and they refer you to the shop manual.
« Last Edit: April 10, 2005, 05:08:39 PM by bashzuk »
Mean Green Wheeling Machine
Offline mesjr2004
  • 422
Re: Locker Install Problems HELP!!!
« Reply #1 on: April 10, 2005, 02:59:19 PM »
i always used a BIG hammer on the back side of the drum ;D
mudfkr
« Reply #2 on: April 10, 2005, 03:01:55 PM »
As mesjr2004 said,
Bolt the drum on backwards and bash the sh!t out of it  ;D
Works every time for me.
Offline bashzuk
  • 784
« Reply #3 on: April 10, 2005, 03:03:27 PM »
hmm I can't get the drum off that side either.
but mayber a some cloth and a hammer.
BRB gonna go try it now.
« Last Edit: April 10, 2005, 03:04:20 PM by bashzuk »
Offline bashzuk
  • 784
Re: Problems can't get driver side axle out!!!
« Reply #4 on: April 10, 2005, 03:20:38 PM »
still no luck.
and now since my aim is bad I pushed one of the axle holding  bolts into the break drum.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: Problems can't get rear driver side axle out!!
« Reply #5 on: April 10, 2005, 03:25:28 PM »
go to orileys and barrow a slide hammer and get the right thread conection and go at it agin it will come off. the drive shaft is pressed in or hammered but the breake drum may be caught on the shoes and is also a very tight fit on the retaining bolts.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
« Reply #6 on: April 10, 2005, 03:25:31 PM »
I use a big honking chain. Probably has more mass than slide hammer. Fasten on the ends with the lug nuts. Put some slack in it, then give it a yank.
87 Samurai
Offline bashzuk
  • 784
« Reply #7 on: April 10, 2005, 03:35:30 PM »
Ok I got the axle out though I may have screwed up the brake assembly. Made my own slide hammer. hammer and peice of metal.
Is there a good way to get the brake drum off with the axle out of the housing.
I pushed one of the housing holding screws into the brake drum. now it's just floating around in there.
)(&%_#&$(_#&_(*#&  that's about how I feel right now.
For something that was supposed to be fairly easy this is really turning into a big pain in my A#$
« Last Edit: April 10, 2005, 03:37:15 PM by bashzuk »
Offline mrfuelish
  • 2862
« Reply #8 on: April 10, 2005, 04:33:48 PM »
I just pull off the four nuts on the axel first and kick the tire around untill the brake drum comes off, if not I put the four nuts back on loose and drive around the drive way till it comes loose then jack it back up and take it off but I just leave the drums on the wheel.
« Last Edit: April 10, 2005, 04:35:38 PM by mrfuelish »
Offline SnoFalls
  • 1358
Re: Problems can't get rear driver side axle out !
« Reply #9 on: April 11, 2005, 03:19:40 AM »
I remember when pulling the axels from my trac/kick the first time, it was a PITA ... second time was easy :)
Some PB blaster soaking couldn;t hurt to get that drum off. some heat after a good soak and a BFH and it'll let go.
Offline SnoFalls
  • 1358
« Reply #10 on: April 11, 2005, 03:34:15 AM »
As for the locker install (since I assume your doing this yourself ...)
check out ...
http://www.puresuzuki.com/ez_locker1.htm
http://bbs.zuwharrie.com/content/topic,9054.0.html
Since your not changing gears, the easiest way to reset the bearing preload in the diff is to make sure you mark the bearing caps and count the turns as described in that second link ...
If you really want piece of mind, you could have the preload checked by a pro (since you're not pulling the pinion, it should be fine).
« Last Edit: April 11, 2005, 03:36:22 AM by SnoFalls »
Offline bashzuk
  • 784
« Reply #11 on: April 11, 2005, 03:54:38 AM »
Sno You rock that is exactly what I was looking for thanks.
Bash
Offline Natebert
  • 1098
« Reply #12 on: April 11, 2005, 06:24:28 AM »
Make a slide hammer out of an old broken axle.
(the bolt flanges will alight right up!)
~Nate
