Neon Seats
Pages:
Neon Seats
Stephenw
27
Re: Neon Seats
Reply #15 on:
October 01, 2009, 07:52:31 PM »
Attach the two triangle brackets to the Neon seat bottoms by putting a bolt in through the side.
Stephenw
27
Re: Neon Seats
Reply #16 on:
October 01, 2009, 07:53:13 PM »
Adjust the Samurai tracks so that the old bolt holes are 15 3/16" apart and square to the seat at the rear. Then carefully mark the track positions on the triangle brackets.
Stephenw
27
Re: Neon Seats
Reply #17 on:
October 01, 2009, 07:54:01 PM »
Remove the tracks and the triangle brackets from the seat. Spot weld the brackets to the tracks. Then reassmble the seat bottom. Install it in your truck and test the operation of the tracks through their full range of motion.
Stephenw
27
Re: Neon Seats
Reply #18 on:
October 01, 2009, 07:54:32 PM »
When you are satisfied the track is working correctly, take the bottom back out, disassemble, and finish weld. Put it all back together and install.
Stephenw
27
Re: Neon Seats
Reply #19 on:
October 01, 2009, 07:55:35 PM »
The passenger side has latching mechanisms on both sides of the track. First remove the link which connects both sides of latch mechanism.
Stephenw
27
Re: Neon Seats
Reply #20 on:
October 01, 2009, 07:55:57 PM »
Remove the cover from the release mechanism.
Stephenw
27
Re: Neon Seats
Reply #21 on:
October 01, 2009, 07:56:53 PM »
The release mechanism that goes under the seat is attached with an E clip and a screw. This cable is what allows the seat to slide forward when released from the rear. The second picture shows the cable on the bottom of the track.
Stephenw
27
Re: Neon Seats
Reply #22 on:
October 01, 2009, 07:57:37 PM »
The passenger tracks are then removed similar to the driver's side.
Stephenw
27
Re: Neon Seats
Reply #23 on:
October 01, 2009, 07:58:17 PM »
I used the same method as on the driver's side to fit, spot weld, test, and finish weld the tracks.
Stephenw
27
Re: Neon Seats
Reply #24 on:
October 01, 2009, 07:58:48 PM »
I drilled and tapped the Neon hinge to install the Samurai release cable. I cut the handle from the Samurai hinge and used a crimp splice to hook it to the track release cable. These were seats from a 2 door Neon, so the seat back tilt was already built in. The cable release is only to slide the seat bottom forward.
Stephenw
27
Re: Neon Seats
Reply #25 on:
October 01, 2009, 07:59:28 PM »
The completed passenger side seat bottom assembly...
Stephenw
27
Re: Neon Seats
Reply #26 on:
October 01, 2009, 07:59:49 PM »
These seats are a huge improvement in ride quality. A very worthwhile modification.
95Gstman
78
Re: Neon Seats
Reply #27 on:
October 01, 2009, 09:45:26 PM »
Very nice work. Thanks for sharing. I plan on putting in new seats in my sidekick someday.
Dennis .89-
54
I Owe I Owe, So Off To Work I Go!!
Re: Neon Seats
Reply #28 on:
October 03, 2009, 10:47:58 PM »
i would recommend if any one would like something new / bucket style and spend a bit more to get
Bomz bucket seats made from memory foam. very good ride comfort and they hold well in the seat for turns and off roading.
Pages:
