4-dr on 34's  Build up progerss
  • 37 Replies
  • 5572 Views
Offline Mike71
  • 1449
Re: 4-dr on 34's  Build up progerss
« Reply #30 on: August 08, 2004, 06:35:36 AM »
it is a little box that sits infront of the drivers seat on the floor..it has a built in compressor and an air cylinder that pushs the break down inside the car...so when u apply ur breaks the car does also
wait u put it on a trailor?? or u flat tow it?? the break buddy will only work if u flat tow lol
« Last Edit: August 08, 2004, 06:36:09 AM by Mhn3773 »
623hp kb cobra sold! 100hp kick new DD :P
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #31 on: August 08, 2004, 07:39:24 AM »
Hmmm...
Sounds cool though...
Offline Speedracer7c
  • 2210
« Reply #32 on: August 08, 2004, 04:14:08 PM »
that jimmy must be pissed!!!  :o
Offline Mike71
  • 1449
« Reply #33 on: August 08, 2004, 04:16:04 PM »
why dont u just flat tow? would save the weight of the trailor wouldnt it??
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #34 on: August 09, 2004, 01:04:55 AM »
For one reason you can not back up when you flat tow.  I have never had to unhook the trailer to turn around, even when towing it with the 32' motor home turning around on a narrow country road.  I can put the trailer exactly into a drive way while backing up and turn it around precisly where I want to.  I have about 20 more good reasons, but the trailer works well for me.
« Last Edit: August 09, 2004, 01:08:22 AM by whitfield »
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #35 on: August 09, 2004, 03:12:57 AM »
One of them wouldn't involve the rear driveshaft blowing out allowing only the "plastic" driveshaft spacer to survive? ;D
www.Zuwharrie.com[/url]
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #36 on: August 09, 2004, 03:16:59 AM »
LOL!!!   Yep, That was Justin and his industructable Plastic drive shaft  spacers....   Or the one where I broke the upper 3rd link the Night before Zuwharrie (Trying to force in a set of TJ coils) and the rear axle (in the picture) is only located by the 2 lower links.  I almost lost the coils by the time I got to Zuwharrie the whole works shifted so much.
« Last Edit: August 09, 2004, 03:18:18 AM by whitfield »
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #37 on: August 09, 2004, 07:46:13 AM »
Well, according to Sean Deskinney a trailer isn't much safer ;)
