GV front brake servicing question
  • 19 Replies
  • 3226 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: April 22, 2006, 06:41:21 PM »
Well, the wife told me it was starting to brake funny.  I was hoping the front pads would last longer until I had the time to put the lift on at the same time...guess not.
So it's on jackstands waiting for the new Bendix semi-metallics.  Brakes aren't my thing so I'm hesitant in doing all this stuff.
Anything I should know or look out for while doing this?
Can I use an impact to get the caliper retaining bolts out?  They're in there pretty good and my 1/2" ratchet doesn't seem to want to budge them.
Offline Carnage
  • 2453
Re: GV front brake servicing question
« Reply #1 on: April 22, 2006, 06:43:38 PM »
did you spray them with WD40 and let um sit?
(If not the impact should be cool)
X32...................X32CarDomainPage...................X32
...................RyouBakua|removethispart|@Hotmail.com..................
!!!!!!!!!!!!!DON'T CLICK HERE!!!!!!!!!!!!![/color]
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #2 on: April 22, 2006, 06:53:36 PM »
go and get yourself some brake lube(silicone) for the sliders and some anti seize compound from the parts store. i also like to spray a little bit of lube under the caliper piston boot (fluid film is great). before installing the pads make sure you clean all the dirt off of the bracket that the pads sit in and put a small bit of the anti seize on the back of the pad - it will keep it from squeaking. if you are not replacing the rotors take them off and using a hammer knock off all the rust ridges on the out side edges of the rotor. i also like to chamfer the edge of the pad a small bit so the paint on the side of the pad does not squeal on the rotor. i think that is it for now. good luck
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: April 22, 2006, 07:46:52 PM »
I'm going to take the rotors in and see what the local machining shop says about turning them.  They look a bit grooved to me.
The squealers didn't seem to squeal. :P
Offline the_maplebar
  • 466
« Reply #4 on: April 22, 2006, 09:53:29 PM »
I couldn't get mine off with a ratchet either.  I was able to get better leverage using a 3" extension and a breaker bar angled out of the wheel well.  Now I'm stuck trying to pull my ball joint out though :'(
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: April 23, 2006, 06:57:34 AM »
Hey maplebar, you have to do anything special to retract the piston in the calipers?
  • 466
« Reply #6 on: April 23, 2006, 07:28:16 AM »
I just used the screw driver trick
http://autos.groups.yahoo.com/group/suzukigrandvitara/message/20602
I'm not familiar with brakes either and didn't notice right away when I had it right, but at some point I noticed that they had a little play when I messed with them by hand.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: April 23, 2006, 07:30:29 AM »
Thanks man, good luck with the lift!
I'll bug you when I start on our GV's lift.  The "instructions" are a bit lacking to say the least. :P  You going mostly by the FSM/Chiltons/Haynes?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: April 23, 2006, 09:02:48 AM »
Well, got the calipers and their brackets off.  Took a 3' long breaker bar and my rubber mallet but they came off.  Kudos to Suzuki for using caliper bolts that aren't little twigs.  I seem to remember my Ranger and my Ram having MUCH smaller caliper bolts...a similar process would likely result in snapped off heads. :-X
Looks like on both sides the inside pad was wearing faster than the outside pad to the extent where the inside pads are practically gone.  In addition the driver's side set seemed to be wearing at an angle which meant the inside driver's side pad was actually dragging the metal backing plate on the rotor where all the material wore off on the rear of it.:o
Now to go find some 8mm bolts at the local hardware store and get those rotors off.  I live in such a bustling metropolis  ::) that none of the machine shops are open today. >:(  Hopefully I can have them turned and have it all back together tomorrow.
Are there any bearings, races, seals, etc on the inside of the rotor?  Never had a Suzuki apart before.  Wish I had thought to take the hubs off BEFORE I disassembled the front brakes.
Since I need the 8mm bolts to take the rotor off...how do I reinstall it?  The FSM just says "reinstall rotor".
Offline 99Trackerconv
  • 430
  • I love my Tracker
« Reply #9 on: April 23, 2006, 09:38:34 AM »
I don't remember using any 8mm bolts when I changed my rotors  ???
If I remember right, I took the caliper and pads off and the rotor just comes off. (with a little convincing  ;D  )
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: April 23, 2006, 10:29:00 AM »
Eh, mine definately needed the bolts.  Although I can see how a mallet and spinning the rotor would work as well.  Oh well, I now have the bolts to do it.  I think they fit the rear drums as well.
Dunno what I was thinking about the hubs, bearings, and rotors either, probably Chrysler and Ford.  Popped right off after some twisting of those 8mm bolts. 8)
I'm sure I'll be back in a day or so with more questions. :P
  • 466
« Reply #11 on: April 24, 2006, 12:20:55 AM »
Thanks, I'm mostly going with the FSM plus cross referencing with the BDS and JDMCRX install instructions.  For the 2nd side I just used the BDS instructions as a check list.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #12 on: April 24, 2006, 04:36:13 AM »
Which BDS instructions are you using?
  • 466
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #14 on: April 24, 2006, 05:26:48 PM »
How'd they seem to work for your newer gen?
