gv front housing
  • 10 Replies
  • 2555 Views
Offline jeff5000
  • 37
gv front housing
« on: May 28, 2009, 06:54:24 PM »
how mutch dose the grand vitara cast iron housing and 3rd member cost?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: gv front housing
« Reply #1 on: May 28, 2009, 08:58:31 PM »
Call your local auto wreckers, I paid 250$ for mine.
  Kevin
Offline jeff5000
  • 37
« Reply #2 on: May 28, 2009, 09:13:13 PM »
ok thats cheeper than i thot i broke the mounting tab off my alum a wile back still ben driving it tho but it thumps and bangs around so thats prob not a good idea lol  ::) need  get it fixed
Offline jeff5000
  • 37
« Reply #3 on: June 01, 2009, 02:09:37 PM »
im having no luck finding one no scrap yards have one and its no longer available from suzuki
« Reply #4 on: June 02, 2009, 08:47:40 AM »
You can give Hawk Suzuki a call, they should have one.  Trail Tough would also be a good place to check.
« Reply #5 on: June 02, 2009, 02:41:41 PM »
I wonder how much it owuld be to have someone tig weld it... and maybe another tab for re-enforcement.
Offline TRAC-9
  • 6
  • LIFE is just LIFE
« Reply #6 on: June 07, 2009, 06:39:39 PM »
I found an article on IZook. It is about a pinion mount for this problem. It is a replacement for a broken one. Could be an option? ;D           izook.com/tech/
« Last Edit: June 08, 2009, 07:10:58 PM by TRAC-9 »
Artificial life starts as Artificial Parts
« Reply #7 on: June 09, 2009, 08:14:41 AM »
Would be nice if you posted a link  ;)
  • 6589
« Reply #8 on: June 09, 2009, 08:24:57 AM »
We've covered this in a couple technical articles. Take a look at our editorial Archives.
http://www.zukiworld.com/main_departments_archive.htm#technical
There are a couple of different ways shown to modify and reinforce the IFS componentry.
« Reply #9 on: June 09, 2009, 04:51:48 PM »
OK - I found the pinion mount article on IZook - took me a few hours, but it was interesting reading.
By the way Eric - I took a look at your link too, and didn't find that much about modifying & reinforcing the IFS - I found two articles, the first on the installation of the Calmini Anvil - I'm not that keen on doing business with Calmini, the last time left me with, let's call it a bad taste in my mouth, and the second on replacing the weaker aluminium stuff with the cast iron, which is kind of hard to come by.
It's important to recognize - it's easy to find stuff when you know it's there and what to look for, but a lot harder when you really have no clue what you're looking for.
So - how about telling me what I missed?
« Reply #10 on: June 09, 2009, 06:17:01 PM »
Modified Sami housing for IFS.
I had this housing sitting on a rack and it sure looked like it wanted to be used, so with a cut off wheel, grinder, and welder it quickly became my steel front diff.
The diff build begins on page 2.  http://www.zukiworld.com/forum/index.php?topic=22395.15
I broke a diff mount and CV joint, and still used it to drive out, but case and third member still fine..  (Sometimes something has to break.)  Lesson learned:  (Do not back up with ARB locked.)
