GV rear gearbox x-member
  • 10 Replies
  • 2699 Views
« on: March 16, 2004, 10:43:18 PM »
Are they the same as a older vitara? Mine is now banana shaped after offroading at the weekend  :( and need to swap it off.
cheers
Steve
Re: GV rear gearbox x-member
« Reply #1 on: March 16, 2004, 10:50:21 PM »
Hi Steve
Tong was a lot of fun but there seems to have been a fair bit of damage incurred by a good number of people. Do you have a pic of the xmember, I have one of the early types for an older Vit if it helps but I suspect that the chassis rails are further apart on the GV.
Offline jagular7
  • 1026
  • Jagular7
« Reply #2 on: March 17, 2004, 02:52:03 AM »
cheers
Steve
Why? If it's bent that it places stress on the mounts on the frame or the tranny mount, then I can see you taking it off, banging it back into shape, then reinstalling it. Simple enough.
There is no particular reason to do it just cause it's bent.
Though after straightening it out, why not get some flat steel and add this as a belly pan.
Lenexa, KS
« Reply #3 on: March 17, 2004, 06:21:06 AM »
I will post a piccie when I have one but the x-member is bent downwards ??? if you look at it from the side the centre box section is now triangle shaped and isnt going to hammer out. Onlt problem is I have half made a full skid pan for under the gv and was to bolt onto the once flat box section of the x-m, wont fit now  >:(
There are ony 6-8 bolts holding it in, seems an easy job just need to find one from a breakers etc cheap ;).
Did see you RM but didnt manage to snap you, too many landies for my liking  :(
Will update my site tomorrow and psot a link to the photos
some i have already done
and richie just about to break a cv  ::)
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: March 17, 2004, 07:15:50 AM »
What an interesting language.  What do you call it ???
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline jagular7
  • 1026
  • Jagular7
« Reply #5 on: March 17, 2004, 02:12:02 PM »
Nice picture of the engine bay. I know the dirt is a lot of water mix (as seen in the pics), but could you look at your air filter to see how much got in there. The cold air draw for the box is the fender in front of the plastic wheel guard, so it would be nice to know how much of the splash gets into the box.
Now, hopefully you already know, that little rubber line and cap just to the left of the radiator along the side of the radiator is the breather for the front axle. The breathers for the t-case and tranny (maybe) are on the trans tunnel just below the block and firewall. You may want to extend those even though they are far behind and way back, but getting stuck and waiting for rescue can prove disasterous. Recall SuperZuk's scenario.
Can't wait for the pics. What's up with RM's yellow light on top?
Lenexa, KS
« Reply #6 on: March 17, 2004, 07:59:18 PM »
Scouse, LOL (you are the wrong side of the pond to get that ;)),
sorry my version of the Queen's English has been tainted by working in Liverpool  ;D
« Reply #7 on: March 17, 2004, 08:02:10 PM »
None  :) clean as new and it stayed dry after my visit to the ford recently (see my site) I think I am going to buy a decent snorkle tho, engines aren't cheap.
« Reply #8 on: March 17, 2004, 08:14:16 PM »
Yes its not in the best place athough you would struggle to get water in it. I was trying to find the breathers for the box and t-case yesterday but they are tucked up at the top of the tranny tunnel on top of the box, plan to extend them up into the A pillar on my drivers side, if i get water in them there i am in trouble  :o
My gas tank skid is also past its best, will have to take that off and weld on some checkerplate.
Steve
« Reply #9 on: March 18, 2004, 07:33:14 AM »
Pictures posted on my site, Richie bust a CV on his v6 and I have just seen my gas tank skid plate is bent again  ::)
« Reply #10 on: March 19, 2004, 12:51:44 AM »
I think you were one of the lucky ones, almost everyone else I knew that was there sustained body damage. Did no one get a picture of that Porsche Cayenne? I think most of the muck around the engine is sprayed around by the fan, you need an electric one with a disable switch for wading.
