Budget 2" Sidekick lift
  • 33 Replies
  • 7679 Views
Offline ngrover
  • 131
Re: Budget 2" Sidekick lift
« Reply #30 on: November 08, 2006, 10:35:53 PM »
not sure if the crow-vics are a little soft on your generation tracker but they are on a Grand-Vitara.. I used toyota 4-runner shocks that feel exactly like stock and provide more extension than the crown-vic shocks. They cost the same as the crown-vics (cheap)
Monroe part number #32248 (1990-1995 Toyota 4-Runner)
ends: S4/L3
compressed length: 12.875
extended length: 20.875
« Last Edit: November 08, 2006, 10:38:10 PM by ngrover »
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
Offline olija
  • 770
    • Check out my cardomain
« Reply #31 on: November 09, 2006, 07:09:49 PM »
So with my 1.5" lift, I need a 1.5" longer shock right? Sounds like the CrownVic shocks are about perfect...or am I missing something?
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #32 on: November 09, 2006, 08:40:30 PM »
well, you could put on a shock that is 3" or 4" longer to get more downtravel
Offline olija
  • 770
« Reply #33 on: November 09, 2006, 08:48:54 PM »
Wouldn't you need longer brake lines and axle linkage then?
Also, I noticed Calmini sells an idler arm brace. Do I need one of them for 235/75 tires or is it more for the bigger 31" and 32" tires?
« Last Edit: November 09, 2006, 10:19:38 PM by olija »
