my tach won't go over 3000 RPM?!
  • 2033 Views
« on: February 26, 2007, 07:50:20 PM »
tach just stops at 3000 - even if i push the engine higher. so, does this sound like a dead tach or is there something else to look for? anyway to bench-test a tach?
tanx
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: my tach won't go over 3000 RPM?!
« Reply #1 on: February 26, 2007, 10:04:49 PM »
  Has the switch in back been moved away from the 4cyl. mode?
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #2 on: February 26, 2007, 10:35:19 PM »
yea, you have to change it to a different mode, mine had a switch but no markings and i just switched it around till it went to 5000rpm, good enought for me
« Reply #3 on: February 27, 2007, 06:08:16 PM »
WOW! thanks for the quick responses!
in my haste to post my first message.... i left out a few important details (newbie mistake - sorry). the tach is a stock tach from a 87 samurai. i pulled the instrument cluster and didn't see anyting that seemed out of place. when i reinstalled the gauges, the tach did manage to make it over 3000 rpm, but it seemed pretty jumpy. probably just need a new tach....
thanks
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #4 on: February 27, 2007, 10:30:15 PM »
if its jumpy it might just be a loose connection
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: February 28, 2007, 12:05:07 PM »
Sounds like the blinker fluid level is low in the tach gyro.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #6 on: February 28, 2007, 01:07:06 PM »
I don't know, usually a piston return spring will do that too.
Aaron
