head gasket and intake gasket question....!!!
  • 1854 Views
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« on: October 03, 2005, 07:38:25 PM »
hi...my radiator is empty by the exhaust its probably head gasket or intake gasket.....
how to check witch one its broke ? i i dont have to change both im happy !!!
sorry for my english !!! thanks !!!
Sidekick 90 2 Door
3" Body Lift
2" Suspention Calmini
31 Mud BFG !!!
Re: head gasket and intake gasket question....!!!
« Reply #1 on: October 03, 2005, 07:45:26 PM »
I think you are going to have to remove the
intake to get the head off, you might as well
change them both, but it probably is the head
gasket
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« Reply #2 on: October 03, 2005, 09:34:00 PM »
i have to check my head whit profesional or whit my eyes its ok ?
Sidekick 90 2 Door
3" Body Lift
31 Mud BFG !!!
« Reply #3 on: October 04, 2005, 08:49:55 AM »
If  you know how to check the head for
warpage (not 100% flat) then you can
check it, but if not, go to an auto machine
shop and have it checked
Offline Dr_xXx
  • 28
  • Yes Baby !!!!
« Reply #4 on: October 04, 2005, 07:00:35 PM »
i change the motor...!!
thanks you !!!
Sidekick 90 2 Door
3" Body Lift
31 Mud BFG !!!
Offline Suzuki1.8
  • 283
« Reply #5 on: October 04, 2005, 07:47:20 PM »
Acutally suzuki suggest if at all possible when changing a head gasket to keep the intake in place on the head. THe head will come off with intake intake. I just did my friends 1.8 which is alot complicated with the chain drive timing.  I removed the head with intake on.
Offline Suzuki1.8
  • 283
« Reply #6 on: October 04, 2005, 07:49:33 PM »
Or by the way a good way to check for a bad head gasket. First check the oil. IS it milky? Second check the exhaust with a paper test that always a good sign to see if a head gasket is gone. and last but not least you can do a compression check to see if you got leakage in compression.
