heat gauge allways maxed out
  • 2539 Views
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« on: June 07, 2004, 05:56:23 AM »
 :o hey everyone my girlfriends samurai is allways pegged out on the heat gauge what could it be? which sensor do i replace or what wires usually mess up?
Offline Zuki One
  • 441
    • ZUKI - PICS
Re: heat gauge allways maxed out
« Reply #1 on: June 07, 2004, 06:17:30 AM »
Bad ground next time you drive it and the temp gauge is up make sure head lights are off and push in the clutch and hold it for about a min and if the gauge starts to drop then thats it!Usually there is a lil wire that goes from the back of the dist to the fire wall it gets corroded and breaks not leaving  good connection "DO NOT" replace with a another wire go to a battery shop get a braided 6 in ground strap and put it in its place ;DThat is only if its just the gauge malfunctioning if it is truley getting hot do a radiator flush and thermostat replacment ;) or the clutch in your fan is tits up :-/ i think that covers it anyone else?
« Last Edit: June 07, 2004, 06:18:24 AM by Bug_d »
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Offline 6feetofAIR
  • 127
« Reply #2 on: June 07, 2004, 06:39:49 AM »
tight man! yes it is only the gauge, that thing runs cool. awesome, so ill just redo the ground from the distributer to the firewall then. thank you, 6feetofAIR
« Reply #3 on: June 07, 2004, 11:39:18 AM »
The sender is under the thermostat,
if the new ground strap doesn't fix it
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #4 on: June 07, 2004, 01:45:39 PM »
Damn i knew i forgot 1 thing? :(
