Help! broke my body mounts w lift kit
  • 45 Replies
  • 12721 Views
Offline 92Sidekick4x4
  • 1456
Re: Help! broke my body mounts w lift kit
« Reply #30 on: November 13, 2004, 07:02:27 AM »
all my body mounts were fine, came off no problem, the one problem i did have where the large philips head screws holding the back bumper cover on were  a pain in the ass
Offline explosivo
  • 3157
« Reply #31 on: November 13, 2004, 07:15:06 AM »
Lol, most of the bumper cover bolts are still in the frame on my Tracker, but the covers are off ;D
omghi2.us[/url]
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
« Reply #32 on: November 13, 2004, 01:48:22 PM »
Well all of this advise is causing me to have confidence in the project again but I will wait a few weeks.  Oh yea,  And the phillips screws?  stripped every one of them as well as some bolt heads.    Used all new sockets, phillips screw drivers of the right size etc.  I just have to redrill, retap etc lots of new holes and make the stuff I broke right again.   And did I mention that I messed up the shift housing (auto shifter) in the center console.  Its ok though I fixed it and it works as good as new.
Now I remember why when I was a house framer they never let me do the fine detail work. . . only the heavy stuff . . .
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #33 on: November 13, 2004, 01:59:59 PM »
the truth comes out! LOL!
I know what you mean though, I'm a heavy wrench myself. I'm just too much of a perfectionist and too stubborn to give up until it's right! LOL!
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #34 on: November 13, 2004, 02:01:10 PM »
Glad to hear you're going for it. Get some PB Blaster at NAPA and spray the bolts everyday until you're ready to tackle it again. ;D
Offline dwcrisp
  • 212
« Reply #35 on: November 13, 2004, 03:02:31 PM »
Anyone else with tips or things to watch out for feel free to reply!!!  The help on this forum has been unreal!
PB Blaster it is.  And a wire brush to clean the threads, fix the front body mount, drill out and tap new bolt holes for the rear bumper,  drill some new holes for the rear bumper cover next to the screws that I "screwed up"   And patience and set aside 3 days to cover any problems that come up, figure out how to move that one stubborn brake line bracket. . .
Do the whole thing after Cristmas when its a bit cooler.
I can make this work!
PS.  One easy thing was the front grill.  Only held in by one bolt in the middle and just unsnaps and snaps back in easily.  I'm going to try to replace it with one from a 98 Sidekick which I think looks better.  Hope it has the same attachement points.
  • 1456
« Reply #36 on: November 13, 2004, 03:55:22 PM »
hahahaha same with mine, i love the zip cutter  ;D took care of the bumper cover bolts no problem
Offline explosivo
  • 3157
« Reply #37 on: November 13, 2004, 03:57:08 PM »
I just yanked and twisted my covers off. ;D
Only tool I believe in is the good old BFH. ;D ;D
omghi2.us[/url]
  • 1456
« Reply #38 on: November 13, 2004, 04:12:31 PM »
ahha lol my BL went in fairly easy, but after i puit it in it wouldnt start, turns out soemthign happend to my o2 censor so i needed a new one, runs good now, preparign to do my 2" spring spacers next. cant wait
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #39 on: November 13, 2004, 05:43:18 PM »
98 Body mounts are differnt from the captured ones pictured.
They are like mine with the Capured nut and bolt easily accessable.
I replace mine with new nuts and bolts after i wrung them off.   But I still don't like the body mount to bushing set up.
ANd   >:(    All my rear bumper cover bolts wrung off too.
« Last Edit: November 13, 2004, 07:56:25 PM by whitfield »
Offline dwcrisp
  • 212
« Reply #40 on: November 18, 2004, 02:21:03 PM »
Well I have the tools to pull out the broken bolts.
Gonna soak the bolts and nuts with PB Blaster.
The front body mount is still gonna be hard to get to from the top but I may just leave that one off.
That left front brake line is still going to be tough but I will figure that one out too.
May have to drill and tap the rear bumper bolt holes to make that work but now I have the tools so that will be ok too.
Now does anyone know the real deal on whether I have to do something with the steering linkage?   This is a 98 model so anyone know for sure?
Thanks everyone
Dave
« Reply #41 on: November 18, 2004, 07:03:56 PM »
A 3" body lift needs steering shaft
mods, a 2" seems to work without
I have a custom 4" BL and had to
add a 3 or so inch section of tubing
Offline Digger
  • 1991
« Reply #42 on: November 19, 2004, 01:50:05 AM »
On mine, the steering shaft was a little short. I had to loosen the bolt at the steering-box end of the shaft for it to slide a little while I lifted the body... The groove for the bolt to ride in and hold the shaft to the splines is elongated to allow for this movement without disengaging.
Offline bioniconion
  • 268
  • I love YaBB 1G - SP1!
« Reply #43 on: November 19, 2004, 02:05:14 AM »
what i don't understand about this is i have a 4inch body lift and i didn't have to adjust anything. i just took the brake line out of the front driver side wheel well clip and disconnected 2 little body-wire clippies by the fuel tank. and i never had a problem.  ???
« Reply #44 on: November 19, 2004, 02:20:04 AM »
Now add 3" of suspension lift   ;)
I have 7" total lift and many more travel,
things get a little stretched at full droop
I took the brake line on the drivers side
(left) for you UK and Aus zukers  :D
and put a Crescent Wrench (adjustable spanner)
on it and rotated the steel tube 90* down,
no more tight brake lines, I did also loosen it
from the strut too so it reaches better now.
« Last Edit: November 19, 2004, 02:22:11 AM by wildgoody »
