Help! Daily Driver Down.
  • 25 Replies
  • 4432 Views
Offline 1969dane
  • 19
Re: Help! Daily Driver Down.
« Reply #15 on: December 23, 2011, 03:29:39 PM »
Still wondering? Are you back to work yet?
Leaf springs rule!!
« Reply #16 on: December 23, 2011, 10:04:10 PM »
FINALLY! I left the 1.6 head on and started expermenting with the timing. I first retarded the timing one notch because I had read on here it would help with bottom end torque. It all but killed what little power I had with the high speed cam. So then I advaced it one tooth over stock and the little hussie came alive. I tried advancing the distributor but got my chatter back which i believe is spark knock. I turned the distributor back and got rid of the chatter kept my power and then put a cold air intake on that helped a little at best. Thanks for the help and so glad it finally runs like I thought it would.
« Reply #17 on: December 24, 2011, 08:43:12 AM »
I still have to put the timing cover on but was waiting untill I got through tinkering with the timing.
Offline 1969dane
  • 19
« Reply #18 on: December 24, 2011, 11:36:04 AM »
 So the 1.6 head on 1.3 block turned out O.K.? What kind of gains did you see. Did you run a 1.3 cam or is there a difference between the two?
Leaf springs rule!!
« Reply #19 on: December 24, 2011, 07:54:28 PM »
It's a 1.3 cam in a 1.6 head. Heavy duty valve springs but not sure I needed them. It's a high speed cam from lowrange.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #20 on: December 25, 2011, 03:42:35 AM »
Glad to hear that you got it and that it was relatively simple. That is a nice clean looking Tin Top you have.  8)
« Reply #21 on: December 25, 2011, 07:38:02 PM »
Thanks, it's got alot more power from pulling out all the way to about 75 mph. It wouldn't hit 60 before if you dropped it off a cliff. My son is home on leave and couldn't believe the difference in it since the last time he rode in it. He said "so, you finally got some power huh". I just grinned.
« Reply #22 on: December 27, 2011, 05:35:40 AM »
Did you set the cam up with a degree disc and a dial gauge? Many reground cams are some way out and really need slotted/adjustable gears to time them corectly. The cam should have come with the timing specs to set it up correctly.
« Reply #23 on: December 27, 2011, 03:31:15 PM »
Great looking engine and engine bay. Good looking rig all around.
Offline 1969dane
  • 19
« Reply #24 on: December 28, 2011, 01:51:21 PM »
 That is one nice rig. The 1.3 cam did you use a dist? Does that need some kind of spacer or adapter. As I said earlier I plan on doing the same set-up and was wondering about all the little details. I also want to run a 1.3 performance cam.
Leaf springs rule!!
« Reply #25 on: December 30, 2011, 07:33:11 PM »
I set the timing to stock and pulled the belt and then advanced the head one tooth and put the belt back on and presto alot of power. I first retarded the timing and with the Low Range high speed cam it killed the power, with it advanced it ran great. I've been trying to fix it up a little at a time and drive it too. The head is a 1.6 with 1.3 dist. high speed cam and heavy duty valve springs.
