31s with 2" coil spacers
  • 2131 Views
Offline TNTracker
  • 37
« on: June 28, 2010, 06:33:40 AM »
Is anyone running 31s with only 2" coil spacers if so how much rubbing. Would like to see a picture of one with this setup also if anyone has one. Almost forgot its a 93 Track/Kick. Thanks
Re: 31s with 2" coil spacers
« Reply #1 on: June 28, 2010, 08:37:33 AM »
Hey,
I am running 2" aluminum coil spacers and 31" X 10.5" X 15" tires.  I did no trimming in the rear and to be honest i trimmed the front fender too much.  The key seems to be the backspacing of the rim, I have 3.75" backspacing and it seems to be fine.
Offline TNTracker
  • 37
« Reply #2 on: June 28, 2010, 09:45:00 AM »
Looks good thanks for posting the pic. So you had no issue with rubbing in the front of the wheel well on the rear?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: June 29, 2010, 12:40:42 AM »
I've just put some 31's (7" rim with a P15 offset) on a swb with no lift. I've folded the seam flat in the back of the front wheelwell (retained the plastic liner), trimmed the front bumper and used some bumpstop spacers but I haven't fully tested it yet to be absolutely sure but so far it seems pretty good.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #4 on: June 29, 2010, 03:29:17 PM »
Interested in seeing this too.  If anyone has a pic of how 31's look on stock 15x5.5 rims, I want to see that.
How does the offset of Samurai rims compare to trackick rims?
« Reply #5 on: June 30, 2010, 09:39:24 AM »
Just to clarify, the rears are not rubbing.  My rims are 8" wide.
Offline ldodge92
  • 107
« Reply #6 on: July 01, 2010, 02:40:05 PM »
Im running 31x10.50s on 15x8 rims. Had to take off the front bumber and front fenders. And had to do a little cutting on the inner fender but it can be done. And ive tested mine to its fullest.
My new addiction
