Help transmisson
  • 1 Replies
  • 1308 Views
Offline moedway
  • 12
Help transmisson
« on: August 25, 2010, 05:42:21 AM »
94 sam i was wheeling yesterday and got stuck. when i got it lossse i drove into s tree put it in reverse and then 1st gear now it wont go into any gear trnsfercase seems to be working is there anything i can check before i pile the cash where its not needed
Re: Help transmisson
« Reply #1 on: August 25, 2010, 08:34:23 AM »
Will it go into gear with the motor off? If so it's probably a clutch/clutch cable problem... especially if you overheated the clutch trying to get out... If not check the shifter... the Kicks have a plastic bushing that can go bad, not sure about the samurai's.
