Help with kick cvshafts!!
  • 25 Replies
  • 4145 Views
« on: October 02, 2010, 05:11:48 PM »
Hello everyone,
i've got trouble with my 90 sidekick cvhalfshafts. its driving me insane!!!, i have 235/75/15's
and the shafts are loose behind the steering knuckle and in 4X4 it roars awful VERYloud it quits on acceleration but push in the clutch and it roars i have checked the lockouts and the bearing seem to be fine but i can move the halfshaft at least 1/4 of an inch in all directions very loose and i can't tell how to tighten them that clip is all there is the only thing i can think of is cutting threads into the shaft and trying a nut but i don't know i'm goin nuts.
please help me!
P.S. i have changed the brass inserts in the back of the knuckle?????? :( :(
Re: Help with kick cvshafts!!
« Reply #1 on: October 02, 2010, 06:09:01 PM »
Have you replaced the shafts recently?
They aren't supposed to move that much,
Did you by chance somehow get CVs from a Sidekick Sport? or GV?
Offline Medford
  • 184
« Reply #2 on: October 02, 2010, 07:50:39 PM »
Why do you ask if they came from a Sport or GV?  Different spline count, diameter, length, or something else?
96 Tracker LSI, 2.5" Pro Comp lift with cooper 30X9.5 STT tires.  A bit of trim and beating to make the front work.
« Reply #3 on: October 02, 2010, 10:18:39 PM »
Sport is wider, and the GV has different length long side axle, about 1/4" longer,
so I'm just trying to sort out what's going on
« Reply #4 on: October 02, 2010, 10:21:13 PM »
um i just went to autozone and told them 90 suzuki sidekick and thats what they gave me so they do seem to me if they where a little bigger in diameter and a little shorter it would help ALOT
« Reply #5 on: October 02, 2010, 10:24:19 PM »
i had the vehicle in 2006 and it did it then who i sold it to just pretty well let it sit and i recently baught it back but it needed shafts when i got it in 2006 and replaced them imediatly so it pretty well has done it since i have had it and also i mistaked it for bad hub bearings till i replaced them with WARN lockouts so idk????
« Reply #6 on: October 02, 2010, 10:26:42 PM »
Autozone shafts are all rebuilts, could be a mis boxed one, or is it both sides?
« Reply #7 on: October 02, 2010, 10:29:18 PM »
both sides can't get over 7mph in 4x4 lol
« Reply #8 on: October 02, 2010, 10:36:04 PM »
does the splined end of the CV bang around loose in the spindle hole too?
Or does it just move in and out of the spindle?
« Reply #9 on: October 02, 2010, 10:43:50 PM »
it doesn't move in the sindle hadly at all and the snap ring fits good had no trouble with the ring either
« Reply #10 on: October 02, 2010, 10:45:58 PM »
So where is the 1/4" movement you are having trouble with?
« Reply #11 on: October 02, 2010, 10:54:33 PM »
on the back side of the tire i can lay down grab the cv and wiggle it all over
« Reply #12 on: October 02, 2010, 10:59:26 PM »
In the same area that you changed the bushings? It shouldn't do that there,
are you sure the CV isn't broken? the shaft moves or no, the whole CV cup part
« Reply #13 on: October 02, 2010, 11:03:26 PM »
yeah where i changed the brass bushings in the back the whole shaft moves as far as i can tell its a good shaft boot is good um the cv shaft its self all moves as one unit inside the spindle.
« Reply #14 on: October 02, 2010, 11:06:00 PM »
like i said it has got me stumped i guess i can pull one out and take it in and mic a new one see if there is a difference?  or are you thinking a shaft off a whole different vehicle?
