Where do I start when my Tracker won't?
  • 10 Replies
  • 2008 Views
« on: March 07, 2010, 06:46:43 PM »
I hav e 95 Tracker 2 door auto ,air ,ps. The last night when I drove it ran great. This morning all it does is crank over with no fire. I put a timing belt and water pump on it last summer at about 115,000 miles. It now has 116,000 miles. Where do I start oo make it run again?
>>>------------>smallcrawler
Offline sir lance
  • 342
  • I love my XL-7
Re: Where do I start when my Tracker won't?
« Reply #1 on: March 07, 2010, 07:28:33 PM »
i bet the fuel driver in your computer went out, it happens all the time.
in other words you may need a new computer.
you can try jumping 12 volts to your fuel pump and see if it starts.
« Reply #2 on: March 08, 2010, 10:42:23 AM »
95s aren't really prone to the bad ECM problem....so my bet would be it is something else.  I posted up quite a few possibilities on your zu post.
« Reply #3 on: March 08, 2010, 11:31:09 AM »
Don't go crazy trying to figure this out, an engine needs 3 things to run,
fuel, spark and compression, since this engine ran great when you parked
it, it has to be fuel or spark, so to test fuel, shoot some starting fluid into
the intake, take off the air cleaner and give it a 1 second burst, turn the key,
if it starts and stalls, you have a fuel system problem, if it doesn't start you
have an ignition problem.
Go try this and report back what happened
« Reply #4 on: March 09, 2010, 07:25:53 PM »
will try this but it will be later this weekend before i am able to get to it
  • 6602
  • 69
« Reply #5 on: March 11, 2010, 09:31:15 AM »
Does your Check Engine light come on when you turn the key on before you crank it?
Bobthebiker
« Reply #6 on: March 11, 2010, 12:23:38 PM »
Another thing to consider.  just because the battery can crank it DOES NOT mean it has enough power to fire the spark plugs as well.   if the battery has been sitting for awhile, throw a charger on it overnight and let it charge before you go all nuts.
« Reply #7 on: March 12, 2010, 08:59:05 AM »
The Tracker was my daily driver until this happened so I doubt it is the battery. Also it ws new when I did the timing belt and water pump last summer. As far as the check engine light I have had this problem for quite some time. It would come on and I would reset it by pulling battery leads. Would go  long time before it came back on.  Other posters have told me not to worry too much about it so I didn't. I have been driving with it on until this no start thing happened. I do not have a code reader.
« Reply #8 on: March 12, 2010, 01:11:22 PM »
Isn't there a problem were if the fuel pressure sensor is not working the system shuts down the fuel pump on the 16v engines?
« Reply #9 on: March 12, 2010, 05:15:06 PM »
You don't have a code reader?  You don't have a paperclip, eyes, and can count flashes?  Those are all you need for reading codes on a 95.
Offline NYSIDEKICKER
  • 29
  • ZUKES ARE BUILT NOT BOUGHT...
    • OLD PHOTOS OF WHEN I FIRST GOT ZUKE
« Reply #10 on: March 13, 2010, 06:47:34 PM »
MY KICK HAD ISSUES STARTING WHEN IT WOULD POOR RAIN LIKE CRAZY A LITTLE SPRAY OF WD 40 TO THE WIRES & CAP AREA AND SHE WOULD USUALLY FIRE UP NOPE NOTTA, THIS TIME. BUT NEW TUNE UP (LONG OVER DUE) AND NOTTA SO I TURNED THE KEY ON AND LISTENED FOR THE FUEL PUMP TO RUN A FEW SECONDS AFTER BUT NOTHING. SO PULLED TANK OUT PULLED FUEL PUMP OUT AND CHECKED BY PUTTING POWER AND GROUND TO THE WIRES AND NOTHING. NEW FUEL PUMP AND WALLA SHE FIRED UP. P.S. DON'T FORGET THE RUBBER GASKET  :P  SO CHECK TO SEE IF FUEL PUMP IS WORKING???
                               NYSIDEKICKER...........
ZUKE MAY BE RUSTY BUT IT SURE IS TRUSTY!
