Trippin'
  • 44 Replies
  • 4950 Views
Re: Trippin'
« Reply #30 on: September 10, 2009, 05:21:42 PM »
I thought about using some nice smooth plastic material for the air dam, but all I had in the garage wide enough was left over diamond plate. I didn't want to spend any $ on it, but I guess I could have sprung for something smooth. I tried plexiglass, but all I had was 1/8th" and when I tried to put two pieces together to make it wide enough it cracked, it was too fragile. This will however give the bugs something to bounce off of!  If it proves to be a failure it's only 3 bolts and some doublesided trim tape away from the dumpster. Besides, how aero does it need to be with average speed around 60!
What was I thinking?  As usual, you have all ready thought it through, weighed the options and determined the best solution under all the circumstances.
Re: Trippin'
« Reply #31 on: September 11, 2009, 04:11:43 AM »
My my  LilRed, you make it sound like I put some thought into these things! At this point I'm pretty sure I've overthought everything!  I've been so keyed up I haven't slept well in days, I need to get to the driving just so I can finally relax!
Offline djlantis57
  • 871
  • Take your chrome home
Re: Trippin'
« Reply #32 on: September 12, 2009, 12:41:33 AM »
Good luck, drive safe.  I'm watching this post for updates.
And...pictures! pictures! pictures!
Re: Trippin'
« Reply #33 on: September 15, 2009, 04:06:26 AM »
Hey All!  So far the ride out has been uneventful. Tracker is running great, lots of rain. 3 days on the raod and I'm In Texsas. Camping in the rain sucks!   I'm going to do a seperate writeup in the adventure forum but I've got a couple of photos in the meantime.
Re: Trippin'
« Reply #34 on: September 15, 2009, 06:08:35 AM »
Ha Ha Ha Ha!  Thanks for that!!
Good to hear from you!
Re: Trippin'
« Reply #35 on: September 19, 2009, 03:03:03 PM »
Hey all! Made it out to Silver City NM with only one minor issue. One of the cooloant hoses to my turbo sprung a small leak near the clamp on the turbo. It figures, I had it on and off at least a dozen times and I must have nicked it pushing it on with a screwdriver. I pulled into the shade of a car wash in Truth or Concenquences NM, and in about 45 min I had the leaking end trimmed off and reinstalled. End of problem.
The drive through Texas and New Mexico was the most difficult. The climb up the Colorado Plateau lasted almost 700 miles, uphill all the way, from sea level to an elevation of 6000 ft here in the southwest part of NM. Of course the mountain passes being much higher. The turbo boost guage was reading boost almost the whole time, in order to keep it at or near 65mph. Usually no more than 0 to 2lbs, only going higher when I really gassed it to climb a paticularly steep grade. I did find the "sweet spot" for running at highway speeds is about 4000 rmp. At that speed I'm running about 68mph, and right in the meat of the powerband torque wise. It will pull uphill on the cruise control without slowing down too much, 2/3 mph. Gas mileage is less than I expected, closer to 18mpg average for the trip, but considering it was on boost most of the time, that's not too bad, and I could run near 70 getting that. Going back to NJ should be much better, seeing that it will be downhill all the way. The  Tracker used no measurable amount of oil during the 2000 mile drive, and ran like clockwork. Aside from the small coolant hose leak, all the turbo related stuff performed flawlessly so far. The manifold and all the other parts I built seem to be holding up just fine. I can't seem to find anything higher than 90/91 octane premimum out here, but it doesn't seem to be an issue, no pinging or any other sign of detonation.
I turned 100000 miles on my odometer and of course the check engine light came on, but it's a non issue. I'll find the switch later and pop it off.
I'll be here in the southern NM area for about 9 days visiting my daughter and then it's down to El Paso Texsas to pick up my wife at the airport there. Then it's up to Utah for some serious wheeling adventures.
I'll keep posting pictures and updates along the way. I ran a bit low on fuel at one point but was curious to see just how far I could go on a tank. The needle actually got below the "E" on the guage  but I still had a gallon left when I filled it up. Yes, I do keep gas in the jerry can just in case!
Offline skitime
  • 302
Re: Trippin'
« Reply #36 on: September 20, 2009, 07:13:58 AM »
Sounds like your adventure is going great.  Can't wait to see your Utah pics.  Wish I would be wheeling with you there.
Offline RHodge
  • 523
Re: Trippin'
« Reply #37 on: September 20, 2009, 01:30:25 PM »
I ran My sami on E for two days before it ran out of gas, It's a good thing I keep 2.5 gal on my AAA card ;)    JK I had some gas with me
It look like a great trip so far
Offline v-stone
  • 625
Re: Trippin'
« Reply #38 on: September 20, 2009, 02:44:42 PM »
Are you planning on coming up to the Salt Lake area on your trip? Would love to see your rig.
SAS Tracker! No looking back now.
Re: Trippin'
« Reply #39 on: September 22, 2009, 10:22:47 PM »
I find it amusing that your GPS sits where a rear view mirror normally does.  Who need to see where you have been when you can see where your going.  :D
Yes, I realize it's probably the picture, but that's no fun.
Re: Trippin'
« Reply #40 on: September 29, 2009, 07:03:43 AM »
Hey all! After spending over a week in Southern New Mexico visiting with my daughter and seeing all the sights, we are now in Moab preparing for our back country trip into the Canyonlands National park. The Tracker has been running great, with no issues to report. Other than having to keep the pedal to the floor to climb some of the longer steeper grades in the mountains, it's been very dependable. I put another 1000 miles on it in New Mexico, and once we got to Moab I changed the oil and filter in a motel parking lot. The only issue I can see is my Calmini front coils are starting to sag once again. Not much, but I'm guessing after wheeling here in Moab there going to be shot.
Of course, after being on the road for over two weeks, I've discovered I severely overpacked. The poor Tracker has been carrying on admirably, even though it's busting at the seams with too much extra junk packed into it and on it. Before we head out into the trails we are going to stop at the local UPS store and unload as much as possible to ship back home. the goal is to try and get everything off the roof to reduce the wind resistance and lower the center of gravity.
There is just so much here in Moab and the surrounding areas to wheel it's really hard to pick what to do. We have 3 days on the White Rim Trail, and a couple days after before my wife needs to board a plane back to NJ. We're going to try and do some trails here in Moab on the slick rock, and maybe spend a day in Arches as well. The pictures are scattered over 4 cameras, my daughter  having the majority of them. I will organize and post them once I'm home.
Re: Trippin'
« Reply #41 on: October 10, 2009, 07:29:32 AM »
Hey all! Back home in NJ and will be putting together a detailed write up of the trip in the Adventure section soon.
Re: Trippin'
« Reply #42 on: October 10, 2009, 07:39:29 AM »
Looking forward to it man.
Re: Trippin'
« Reply #43 on: October 10, 2009, 08:13:57 AM »
Re: Trippin'
« Reply #44 on: October 10, 2009, 10:36:04 AM »
Good to know the first trip went without engine problems.  Congrats and welcome back.  :D
