high idel problem help
westvilleguy
53
I Love ZUKIWORLD!
August 22, 2006, 02:17:17 PM »
my 91 tracker starts up fine idels good then when it gets warm it idels high and the check engine light comes on any one know what could be causing this
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Yoak
577
Re: high idel problem help
August 22, 2006, 04:39:27 PM »
This probably won't apply per the check engine light issue...
There is a screw that does adjust the engine idle speed right behind the throttle body
Rhinoman
4502
36
Bend it, Break it, Fix it
August 23, 2006, 05:01:56 AM »
Pull the codes from the ECU. It sounds like the throttle opener may not be pulling back properly. Check the connections to the Vacuum Switching Valve (front of engine) and the vacuum lines.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
