4 door springs with 2" lift?
  • 15 Replies
  • 2794 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: 4 door springs with 2" lift?
« Reply #15 on: October 02, 2004, 12:24:35 AM »
the coil spring compressors are good when your by yourself with no one wanting to help you.
but, i always make sure i can get 2 on a coil, directly or as close as possible to being opposite the other, as in, one on each side, so that it doesn't form a banana under a lot of pressure.
from the first time i had to remove coil springs, i'm still quite scared of them coils. after you've seen or known what damage they could/can cause, you'll be the same.
