Hood Fitment Question???
  • 13 Replies
  • 3023 Views
Offline efalk
  • 14
« on: June 14, 2009, 07:50:45 AM »
Hello.
This weekend I managed to damage my hood on a trail.   I found a hood on line, same color but its about an hour away from me.   My question is I have a 97 2door sidekick and the hood is from a 92 sidekick.   I know that they are different hoods but does anyone know if I can make the 92 hood work with out too much modification?
Thank you.
Re: Hood Fitment Question???
« Reply #1 on: June 14, 2009, 04:01:15 PM »
There shouldn't be any difference in hoods between a 92 and 97 sidekick.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #2 on: June 14, 2009, 04:30:38 PM »
They do look different, but they bolt up and latch. The older Tracker hoods don't have the
"suzuki hump" like the Suzuki badged, and 96+ Trackers.
Offline 4Zstracker
  • 250
« Reply #3 on: June 14, 2009, 04:42:15 PM »
Ive used a 91 2 door hood on my 97 4 doors no probs, they bolt up the same, just dont have the raised center section.
if ya always do what ya always done, you always gonna get what ya always got...
Offline zukimoo
  • 330
« Reply #4 on: June 14, 2009, 04:54:11 PM »
when you re-bolt on any hood you should drop it down very slowly to try to fit it. I changed one last summer and slammed it shut. Well it wasn't lined up and when we tried to re-open it there was no way that it wasn't going to cause some body damage and break some plastic piece close to the glass.
I tried to get my hands in there to loosen some bolts but there was no chance of that. I ended up cutting the hood to get it off and having to find another hood. Don't do like me....take you time, I just rushed and like normal it cost me some money. Just another stupid thing to add to my list.
06 Baja Buggy
Offline efalk
  • 14
« Reply #5 on: June 14, 2009, 05:08:02 PM »
Hey, thanks so much guys!!
I really appreciate the help.
  • 4327
« Reply #6 on: June 14, 2009, 05:21:59 PM »
I thought so too, so I looked it up - and the part numbers were different, I can't tell you what the differences are, but they are different.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #7 on: June 14, 2009, 07:56:21 PM »
When I whacked a deer with my '96 Tracker, the only hood I could find was a flat hood from a '92 or '93.  It bolted right on, and the latch lined up perfectly (once I pulled the front end out straight.  The only problem I had was that the washer nozzles spray the under edge of the hood and had to be bent a little to work properly.
Before:
After:
Jim Z.
96 Tracker
66 Apache camper
« Reply #8 on: June 15, 2009, 11:03:00 AM »
So jzap is the one that took out Bambi's mom.
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
« Reply #9 on: June 15, 2009, 06:41:01 PM »
The "hump" and "no hump" hoods will have different part numbers, even though they are totally interchangable.
Offline efalk
  • 14
« Reply #10 on: June 15, 2009, 06:50:21 PM »
Thanks For all the help guys!!
  • 4327
« Reply #11 on: June 15, 2009, 07:00:58 PM »
I never said they weren't interchangeable - just that they were different.
So to speak - there is a difference between "shouldn't be any difference" and "interchangeable"  :P
« Reply #12 on: June 16, 2009, 06:12:31 PM »
I guess I should have said...."there shouldn't be any difference in fitament of the hoods between a 92 and 97 sidekick".  Seeing as how the original poster was just wondering if the 97 hood would fit and didn't care if it looked different, then my answer should have been pretty clear.
Everyone else seemed to know what I meant, except for you.   :P
Offline jzap
  • 515
« Reply #13 on: June 20, 2009, 09:48:34 PM »
No, It was Bambi's DAD...  ...8 pointer at 50MPH.  Had to wait for daylight, but drove Tracker home...
Jim Z.
96 Tracker
66 Apache camper
