1" Tracker body lift
  • 1564 Views
« on: May 15, 2007, 11:09:33 AM »
Can someone advise me how to make 1" body lift on a 4-door Tracker. All kits I see start at 2"....
g-man
Re: 1" Tracker body lift
« Reply #1 on: May 15, 2007, 07:52:11 PM »
Hockey pucks.
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #2 on: May 15, 2007, 10:21:59 PM »
Never heard of 1"; plenty of 2" and 3" though.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline Carnage
  • 2453
« Reply #3 on: May 15, 2007, 10:44:03 PM »
curious
why a 1"?
« Reply #4 on: May 16, 2007, 11:35:26 AM »
3" is easiest to make. 2" is more difficult requiring sleeve bolts. 1" I would imagine would have to be of a similar design to the 2", take a look at the Rock Road kit. The problem is that the Track/Kick has studs welded into the body and they can't easily be changed for bolts of a longer length.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #5 on: May 16, 2007, 02:31:11 PM »
Check out SKY's sami. 1inch B/L It should work on a kick. ???
      Kevin
