wire to power steering pump?
  • 11 Replies
  • 4421 Views
Offline chet
  • 556
  • Zuki time!
« on: July 19, 2005, 02:27:51 PM »
OK while doing my bodylift on the weekend I saw a wire hanging loose by the power steering pump. There is a terminal on the pump which looks like it is supposed to be attached to(if the plug was not busted)
What would this be for? Sensor to tell if the system is empty?
Offline mrfuelish
  • 2862
Re: wire to power steering pump?
« Reply #1 on: July 19, 2005, 02:58:21 PM »
I have a yellow wire hooked to mine, it's for raising up your idle when there is pressure in the pump, there is also another one for your ac. ( even if you don't have ac. it's there.) hope that helps. solder works great.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #2 on: July 19, 2005, 04:04:35 PM »
i don't have mine hooked up and i do have to give alittle more gas when under stress turning.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline mrfuelish
  • 2862
« Reply #3 on: July 19, 2005, 04:23:40 PM »
as long as your f.i. is in closed loop your engine will adjust if working properly, maybe the wire helps it react faster or maybe takes it to 1k on idle? it's there for a reason.
Offline chet
  • 556
  • Zuki time!
« Reply #4 on: July 19, 2005, 09:29:59 PM »
interesting! I will hook it up tomorrow night. I have noticed that when crawling it tend to be harder to steer.  ;D
Thanks!
« Reply #5 on: July 20, 2005, 04:56:44 AM »
I have that on mine too. It didn't seem to make any difference hooked up or not. When I had the ECU apart I noticed that there were no components fitted on that circuit.
Offline toolman21
  • 229
  • 89 Kick with 5" lift and 30's
« Reply #6 on: July 20, 2005, 02:30:50 PM »
Mine has been unhooked for about 7 years now and I always wondered what it was for, never could find a matching end that was empty.  On the other hand It has never been hard to turn either.  I don't have AC, so where should this yellow wire be coming from if I were looking.  Haven't needed it so far, but couldnt' hurt to try it.
Toolman
« Reply #7 on: July 20, 2005, 02:39:26 PM »
There should be pressure sensor on top of the power steering pump. Too dark to take a pic now.
Offline toolman21
  • 229
« Reply #8 on: July 22, 2005, 07:47:02 AM »
No I see the sender and wire coming from the top of the pump, just dont' see anywhere in a harness on the engine to plug it into. :D
Toolman
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
« Reply #9 on: July 22, 2005, 10:29:49 AM »
Power steering is for the weak :)
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Offline chet
  • 556
  • Zuki time!
« Reply #10 on: July 22, 2005, 10:56:33 AM »
power steering is for lucky!  ;D with a 4 door I think its a requirement!
« Reply #11 on: July 22, 2005, 01:10:11 PM »
Misunderstood. On mine it goes up under the headlight. The wire is covered with an outer sleeve (heatproofing?) so it doesn't look very yellow.
