making some rocker gaurds.
  • 37 Replies
  • 8462 Views
lucszuk
Re: making some rocker gaurds.
« Reply #30 on: March 26, 2004, 08:16:30 AM »
how are these rockers coming along any way?
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
« Reply #31 on: March 26, 2004, 10:47:03 AM »
Heh I'm just waiting on some material because I changed the mounting design again.  :P
My newest plan is to get a larger piece of rectangle tubing and hack off one end.  Then I'll slide it over the frame from the bottom up and place two bolts in the top so it clamps tight.
My uncles shop didn’t have any tubing that was big enough so I gotta pick some up tomorrow from the steel recycling yard.
« Reply #32 on: March 26, 2004, 10:49:10 AM »
Lets talk cost for the headers...  zip is Michigan 48618
And don't tell my wife! I may not live to buy em ;D
You are talking Turbo Header right ?
Shipping is about $20
Offline MB
  • 223
« Reply #33 on: March 26, 2004, 11:45:34 AM »
nope, just a good header for a 2 inch exaust mod ;D
« Reply #34 on: March 26, 2004, 06:15:07 PM »
I think a tuned header from Hawks would be
a better performer, I build headers from Sched.
40 Weld Ells and iron, it would weigh about 40 Lbs.
Offline jagular7
  • 1026
  • Jagular7
« Reply #35 on: March 27, 2004, 04:36:48 AM »
Got to be careful on the square tubing. The internal radius of the material may interfere with the external radius of the frame.
Have you thought of taking a square plate, welding tubing to it, then drilling the outside portion of the  frame the diameter of the tube, and drill the inside of the frame the bolt diameter. Support the bolt head with a flat metal. Use 4 bolts, mounting in 3 places on the frame, and you should have plenty of strength. Then to add, make the interior plate with a flange so as to mate a skid plate to it.
Just my thoughts after laying underneath my XL7 yesterday.
Lenexa, KS
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #36 on: March 28, 2004, 09:34:29 AM »
96 Tracker
32 MTR's Warn 8000i
lucszuk
« Reply #37 on: March 28, 2004, 01:40:43 PM »
i liek my rocker simple i 2 inch square tube bet 90 degres at boht ende with a plate and u bolted to the frame . i can hi lift it on to tires from them. :) :)
