how to drain the Trans?
  • 14 Replies
  • 3847 Views
Offline 99Trackerconv
  • 430
  • I love my Tracker
« on: March 17, 2005, 08:50:57 PM »
I'm gonna change to Synthetic, but need to now how do I get as much of the old gear-oil out of 5spd trans in my 99 Tracker as possible. I don't  want to mix it all together if I don't have too.
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: how to drain the Trans?
« Reply #1 on: March 17, 2005, 08:55:56 PM »
Isn't it just like any other oil removing thing, get the filler plug out and the other plug (don't know what it's called) put some sort of bucket under it and wait...... Untill nothing is flowing out anymore. You won't get all of it out but that shouldn't be too much of a problem.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline adamd
  • 369
  • sofa king we todd it
« Reply #2 on: March 17, 2005, 11:41:12 PM »
......... What he said, plus gear oil is cheap. You can always buy walmart brand and flush it out before you put the good stuff in.
'98 kick
3" B/l
30" Mud Kings
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #3 on: March 18, 2005, 03:31:39 AM »
Yeah, while a .44 Magnum will do a fair job of draining your juice, it's alot better to pull the fill plug, and the drain plug to get it out.  When you do it, it will work best to have the vehicle level.
So, if you use ramps, use TWO SETS, and get all four tires off the ground.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
  • 430
  • I love my Tracker
« Reply #4 on: March 18, 2005, 05:03:10 AM »
You guys are such a pain.  ;D  ::)
Thanks, I wanted to know if it sould be level or tilted more than anything.
I looked a walmart but the only full synthitic gear-oil I found was for boats. I guess I need to go to AutoZone.
Offline bus_driver
  • 479
« Reply #5 on: March 19, 2005, 03:41:16 AM »
since we are on the topic.... I am going to change all the fluids diffs and transfer case .....roughly how much oil does each take so I can buy enough on one trip.
????? when running skid plates how do they mount since you do need to get the oil change areas at least once a year.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
« Reply #6 on: March 19, 2005, 05:51:17 AM »
SideKick
Front diff .....................1.1qts  API GL-5 SAE 75W-90
                                                or 80W-90 gear lube
Rear diff ......................2.3qts  API GL-5 SAE 75W-90
                                                or 80W-90 gear lube
Manual Tranny ............3.2pts  API GL-5 SAE 75W-90
                                                or 80W-90 gear lube
Transfer case...............3.6pts  API GL-5 SAE 75W-90
                                                or 80W-90 gear lube
Auto Tranny.................3.0qts  Dextron II or III auto Tranny fluid
  • 430
  • I love my Tracker
« Reply #7 on: March 19, 2005, 07:25:19 AM »
Went to Autozone and picked up Mobil 1 Syn gearlube.
Book calls for 75w-85 GL-4 in the trans but they didn't have any so I asked and they said that the 75w-90 GL-5 is ok to use. I hope thats right.
« Last Edit: March 19, 2005, 07:27:25 AM by 99Trackerconv »
Offline adamd
  • 369
« Reply #8 on: March 19, 2005, 12:56:31 PM »
Yeah, and my Walmart has that ;D
'98 kick
3" B/l
30" Mud Kings
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #9 on: March 19, 2005, 01:19:45 PM »
Called the Suzuki dealer about this very thing today and they said the same thing. Use 75w90 Synthetic, it's what they use in their shop.
Because Mom's is a Tracker I called the Chevy dealer and they quoted me $20.00 a quart for 75w85. ::)
  • 430
  • I love my Tracker
« Reply #10 on: March 19, 2005, 03:19:14 PM »
Well I changed it and the old stuff was black and a little sparkley  :(  I figure it's got almost 80K on it so I'd change it. Glad I did.
But is there any eaiser way to fill it? I had a really hard time geting the bottle tiped up high enough to empty and not pour out on the floor too.
« Reply #11 on: March 19, 2005, 04:31:04 PM »
Break down and buy a hand pump.
Offline bus_driver
  • 479
« Reply #12 on: March 20, 2005, 04:29:17 AM »
hot rod thank you so much for the info I would have not bought enough  ....since I have 200000kms it should be time to change it right ??? ???
amazing what people do to their vehicles.....I got it and the clutch has never been adjusted and the tires never rotated......oh yeah they used 4x4 for real bad rain
92 2dr soft top
235/75/15
2 inch lift
custom mud
« Reply #13 on: March 20, 2005, 12:59:27 PM »
Glad to be of service ;D I have one Haynes manual on my PC desk and one in the garage ;D
(thought I lost one and bought another)
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #14 on: March 20, 2005, 04:50:08 PM »
When I change fluids engine or otherwise I always go for a drive and warm it up, you get more of the old fluids out and more of the bad stuff ( filings, sludge etc..)
Caution: if you drive to long the fluids will be extremely hot, that's right I speak from experiance (OUCH!) :-[
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
