does anyone know if the pins from the ecm have the same range/signal as aftermarket gauges? if not then ill have to run new taps, i was just thinking that it would save a lot of time and hassle if they worked.
im looking at autometer if that helps
i.e. fuel level, oil pressure (is it a pressure switch or is variable) tach, volt meter, ECT.
im in the process of a 2.7L swap and i figured its a good enough time to go to better gauges than "H-C"
