How to remove top strut bolt
  • 12 Replies
  • 4069 Views
Offline BFM
  • 49
  • 4x4 oh yeah!
« on: October 24, 2005, 11:29:11 AM »
What is the best way to hold the strut from turning while you unbolt the big nut on the top end?  (I do not have an impact gun)
'93 Geo Tracker, 3" suspension lift, 31" tires, dome light replaced with cadilac LED brake light bar, tinted, towed home once, dropped off of tow truck once, top speed attempted/achieved 135 km/h = shaking baby syndrome
mudfkr
Re: How to remove top strut bolt
« Reply #1 on: October 24, 2005, 11:39:45 AM »
I'm assuming you have it off the truck so you could try wrapping the shaft up in rags or the likes and putting in the vice to hold it, thats what I've done before.
HTH
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: October 24, 2005, 12:05:02 PM »
Use a large set of channel locking pliers to hold the hex-keyed washer that's just under the nut while you try to remove the nut with a wrench...
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #3 on: October 24, 2005, 01:30:50 PM »
I just use a 1/2" impact gun to take them off and put them on.
Bill
Offline SnoFalls
  • 1358
« Reply #4 on: October 24, 2005, 01:35:54 PM »
same approach here, except I use a pipe wrench ..
Offline Cwkick
  • 888
« Reply #5 on: October 25, 2005, 07:38:44 AM »
I loosened mine while it was still on the Tracker.  I wrapped a rag around a large screwdriver and stuck it between the large hex nut and the strut tower.
Cwkick
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #6 on: October 25, 2005, 07:58:54 AM »
First time, I had someone hit it with am impact gun. I would suggest just running to a local shop, and asking if they could hit it for you, then just retighten it with hand tools, and it will come off MUCH easier after that.
Also, as said, channel locks on the hex part of the strut.
Offline mrfuelish
  • 2862
« Reply #7 on: October 25, 2005, 11:05:52 AM »
spray it a few times with liquid wrench and let it soak in it will help alot.
Shilly
« Reply #8 on: October 25, 2005, 08:06:27 PM »
I recommend the vise-grips and rag technique; if you're taking them off to toss, you can omit the rag part for the removal...  ;D
« Reply #9 on: October 25, 2005, 08:14:10 PM »
Get an impact, you will need it many more times
Offline bus_driver
  • 479
« Reply #10 on: October 26, 2005, 12:45:40 AM »
Impact Gun and when you do it have someone drive really fast and stop in front of your house (do this on a busy sunday afternoon) then run out in your mechanics suite and a closed faced helmet and quickly hit it with the gun. oh yeah and have a flag person to tell the driver where to stop.......    ;D
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline BFM
  • 49
  • 4x4 oh yeah!
« Reply #11 on: October 26, 2005, 01:04:53 PM »
Yeah that's the stuff I was looking for.  The large plate at the top was bugging me it really stops the bolt from breaking loose.
I will also try to get some air tools since I have a compressor.  I'll work on the costume later though, maybe just to get chicks to fully dig me and crap!  Cause you know bus drivers pull chicks all the time  ;D and I want to be like that too.
Offline bus_driver
  • 479
« Reply #12 on: October 26, 2005, 06:27:39 PM »
ahh jealousy in the air you wait till they see me in the grimm reaper uniform and the bus has funeral on the destination sign...... I get paid way too much for this shit.......oh welll city employees have nothing better to do.    ;D ;D
92 2dr soft top
235/75/15
2 inch lift
custom mud
