is there an easy way to change the heater core?
  • 4627 Views
Offline 4njeep
  • 113
  • I Love ZUKIWORLD!!!!
« on: August 13, 2007, 07:35:37 PM »
Just wondering if there is an easyer way to change the heater core in a  92 2dr sidekick, other than what the fsm says?
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
g-man
Re: is there an easy way to change the heater core?
« Reply #1 on: August 13, 2007, 08:14:31 PM »
I have never changed one but I have torn a tracker down clear to the firewall. Looks like the only way to get the box out is to have the dash out of the way. Is that what the service manual is saying?
Offline 4njeep
  • 113
« Reply #2 on: August 14, 2007, 05:34:32 AM »
yeah pretty much, i just took a quick look over it, and seems like i have to rip mostly everything out. oh well, just thought i would ask. you never know, someone might have had a quick and easy idea.
2" suspension lift
kingzoo
« Reply #3 on: August 16, 2007, 06:15:05 AM »
   I wish the same thing every time I do one.
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #4 on: August 17, 2007, 05:43:52 PM »
Sure it's easy just remove the front and rear half of the car and there is your heater core.   >:D  It's actually not that hard just move the seats back and lean them all the way back, Expect to spend some time on your back streatched out in the seats and at the chiropractor later.
You don't have to remove the steering wheel or disconnect the steering shaft, just stretch the dash gently after it is as unbolted as far as you can get it. I had some slight scratches on mine but it wasn't the worst.
If your heater core is plugged internally you can use compressed air to blow it out(in reverse direction) with limmited success, but mostly it is dirt, dead leaves, lent, and the occasianal dead rodent impeading air flow through the core. Or they are hard plugged.
When taking apart the air box (on a bench) it is easiest to put a flat blade screw driver on the outside of the horseshoe shaped clips and twist as aposed to prying, be carefull when reinstalling as they tend to bite at fingers.
Good luck and do it when it's warm instead of waiting 'till late november in an open car port with an electric space heater in the back seat.    ;D    NMc
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
