Hybrid Front Axle Vitara
  • 11 Replies
  • 3301 Views
Offline yuri
  • 87
« on: May 23, 2009, 10:53:33 AM »
Those things cost me about $320, including 2 Ranger Front Axle (New). It works great with ARB front Locker
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
Re: Hybrid Front Axle Vitara
« Reply #1 on: May 24, 2009, 02:33:05 PM »
How are those made?
Student of Now Master of Then
« Reply #2 on: May 25, 2009, 09:32:07 AM »
 ??? Photoshop?
Offline yuri
  • 87
« Reply #3 on: May 26, 2009, 07:52:12 AM »
It's a real Things :)
« Reply #4 on: May 26, 2009, 01:36:30 PM »
It looks like they are using upper halfs and the shaft out of a ranger with the lower birfield from a Tracker.
« Reply #5 on: May 28, 2009, 06:19:46 AM »
OK, what's the advantage?
« Reply #6 on: May 28, 2009, 08:50:13 AM »
Stronger shafts?
« Reply #7 on: May 28, 2009, 01:02:22 PM »
It looks like a larger upper birfield as well as shaft.
« Reply #8 on: May 28, 2009, 03:43:55 PM »
Define "upper birfield" please - I can understand inner & outer, but upper?
« Reply #9 on: May 28, 2009, 06:05:42 PM »
Well, the inner one.  I called it the upper because it usually is higher in the air then the outer one.
What can I say, I usually work with straight axles.  :D
« Reply #10 on: May 28, 2009, 09:14:42 PM »
Yes - the inner does look larger & I assume stronger - thanks for explaining.
Offline yuri
  • 87
« Reply #11 on: June 02, 2009, 07:06:30 PM »
Stronger and better!, The plan was, better Traction. ARB Front Locker. Strong axles and Steel front housing. I made front steel housing from Rear 3rd members samurai housing.
