Wheel Wells on 96 Tracker
  • 1 Replies
  • 1643 Views
Offline sklope
  • 135
  • BUSHWACKER
« on: September 04, 2007, 09:48:58 PM »
Ok, I need to know if anyone has changed out their wheel well plastic? This is the thin plastic directly behind the front wheels. I messed mine up while bending the lower part of the wheel well back for clearance for bigger tires. There is little room for a screw at the area that I bent back.
1. Has anyone used something different in this area?
2. Has anyone just taken them out and running without them? I would think that this might be a problem due to getting mud into the door hinges and seals.
Thanks,
S
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
  • 6602
  • 69
Re: Wheel Wells on 96 Tracker
« Reply #1 on: September 05, 2007, 09:01:36 AM »
Thanks,
S
Yep, run without them and yes it is a problem for mud and goop to get in behind the door. Make sure and really, really wash it out when your done.
