i need torques specifications
paps133
166
make your own road..
June 29, 2004, 02:13:38 PM »
hey guyes i changed my brake tonigh and i needed to know what the torques specs for the caliper mounting bolts. thanks pierre
Whipp
62
Re: i need torques specifications
June 30, 2004, 08:25:28 AM »
For what vehicle?
For a 1989 2 door 4x4 sidekick, the caliper pin bolts are supposed to be torqued betweeen 16 and 23 lb-ft.
- Craig
1989 Sidekick with 3" Calmini suspension, Old Man Emu Struts, Calmini header and exhaust combo, A/C on board air.
- Sold to my brother!
jerryp58
449
June 30, 2004, 10:34:27 AM »
Wow! This is horrible.
I tried to look this up in my 1990 Geo Tracker Service Manual. I couldn't find the torque specs on the caliper mounting bolts. The spec on the caliper pin bolts is listed as 65 ft-lbs.
Then I looked in my Haynes Manual for 1986-1993 Samurai, Sidekick and Tracker and found 29 to 43 ft-lbs for the caliper "holder" bolts (which I'm assuming are the "pin" bolts) and 36 to 57 ft-lbs for the caliper mounting bolts.
These two manuals are really falling short in this department
Jerry
1990 Geo Tracker, 2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
Whipp
62
Reply #3 on:
June 30, 2004, 11:05:21 AM »
That is quite a difference! I got my value from the 1989 Sidekick Factory Service Manual.
- Craig
idaholwb
772
2
And that's the way the metal crumpled!
Reply #4 on:
June 30, 2004, 01:06:53 PM »
Not sure, but I always turn the bolts with a 3/8" drive Craftsman(brand not specific, just a size reference) ratchet just a little past snug. Tap it with the palm of your hand to a firm stop.
That's just I do it, hope that helps.
97 Sport
265/70-16s
2" lift
2.0 swap
