Sidekick Pitman Arm
  • 3047 Views
Offline Yoak
  • 577
Sidekick Pitman Arm
« on: May 15, 2007, 09:31:01 PM »
Hey Gang,
I have been reading and I have seen some sites mention a pitman drop arm for a tracker/sidekick...
Is this in fact accurate?
I know they are made for the Sammy with kick components...
Offline hcgalvin
  • 1695
    • Granite Path
Re: Sidekick Pitman Arm
« Reply #1 on: May 16, 2007, 06:56:06 AM »
Yep. It's accurate. Call Trail Tough, if you want one. I think they have to have a core to make a drop with.
Here's mine.
http://www.granitepath.com/~kd7hcg/sidekick/pictures/tcaseandpitman/index.htm
Heather Galvin
Offline DaddyDave
  • 204
  • Indeed
« Reply #2 on: May 16, 2007, 09:34:42 AM »
meanwhile, they're in stock here: http://www.puresuzuki.com/kick_pitman_arm.htm
"The maximum effective range of an excuse is 0.0 meters."
Offline Yoak
  • 577
« Reply #3 on: May 16, 2007, 11:42:03 AM »
The one from Calmini though states it works on a Sammy, but will it work on a kick.
If all else fails Ill call trail tough :)
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #4 on: May 16, 2007, 12:26:22 PM »
The calmini says it's for the sidekick box, which some people use in the samurai.
1993 4-door Sidekick
4.24:1 t-case
