'87 Samurai trouble/warning lights
  • 11 Replies
  • 3709 Views
« on: June 11, 2008, 03:06:19 AM »
Hello, new member here, glad to have found this site. I just got an '87 Samurai a couple months ago (yea!) and haven't had any mechanical problems until now. On the dash where the turn signal indicators, high-beam indicator and seatbelt lights are there is a light that says sensor, and it's been coming on the last couple days. I have the repair manual, but no where does it cover the warning lights. I'm assuming that info is in the owner's manual, which I do not have.
    Which sensor is it referring to? Any help is much appreciated. Thanks in advance>
Offline Amilla
  • 1076
Re: '87 Samurai trouble/warning lights
« Reply #1 on: June 11, 2008, 11:02:42 AM »
Is it running any different?  Or did the light just start coming on?
Amilla
Offline ROSS
  • 1412
« Reply #2 on: June 11, 2008, 08:47:14 PM »
mine goes on and off for the past 3 years.  runs fine
Offline samurai87
  • 40
« Reply #3 on: June 11, 2008, 10:30:13 PM »
I just got mine running  ;D and it does that too it just flashes on and off.
1987 Samurai Locked and loaded (with a Lock Right)
« Reply #4 on: June 11, 2008, 11:19:07 PM »
it runs fine, no different than before, but i know it won't pass smog with it on, and I need to smog it.
Boo California  >:(
« Reply #5 on: June 12, 2008, 05:09:36 AM »
take the dash off and cut the wire.  no dont listen to me, i live in texas, we dont have to pass smoke. just a safty test
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
« Reply #6 on: June 12, 2008, 06:42:51 AM »
just remove the little bulb...
« Reply #7 on: June 12, 2008, 09:48:04 AM »
I figured it out, apparently the little switch under the dash does have a purpose. It's a reset switch for the check engine light, which is what the 'sensor' light is. I flipped it the other way and poof! no more flashing light.
Offline Amilla
  • 1076
« Reply #8 on: June 12, 2008, 10:40:57 AM »
From what i have read the light comes on every certain amount of miles for service reminder, and that switch is to reset it/turn it off.
When i got my sami, i pulled the gauges out and found that the owner before me didn't know about that little switch...so they just put some black tape over the light.
Amilla
« Reply #9 on: June 12, 2008, 05:10:38 PM »
were is the switch yall are talking about?
Offline RHodge
  • 523
« Reply #10 on: June 13, 2008, 10:32:05 AM »
mine was under the steering column,  just a little black switch
« Reply #11 on: June 13, 2008, 12:41:11 PM »
thanks. i found it
