Ignition coil popping fuses...
Chief
678
Whaddya lookin at??
February 07, 2007, 06:31:57 PM »
see other thread....
Last Edit: February 08, 2007, 05:29:32 PM by Chief
03 Tacoma, BBP sliders, TRD L/S, Modded intake, Da Tow Bitch
reb
195
Victim of CRS--Can't Remember Anything.
Re: Ignition coil popping fuses...
February 08, 2007, 11:26:22 AM »
If you hear a "pop," I would suspect a hard short to ground. If you measured the resistance to ground at the circuit side of the fuse, you will probably read less than 1 ohm. I would look for a pinched wire.
Rhinoman
4502
36
Bend it, Break it, Fix it
February 08, 2007, 12:03:37 PM »
Disconnect the coil and see if it still does it. That should tell you if its the coil or the wiring.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
