Injector noise
  • 8 Replies
  • 2735 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Injector noise
« on: November 26, 2005, 05:21:06 PM »
I recently bought a 94 4 door Sidekick with a 16v and have been going through things getting it up to my liking. It has had a miss under load from about 2000rpm and up. I have done a complete tuneup and ran a few jugs of cleaner through the fuel system as well as some intake cleaner down it's throat. Today I noticed that I was getting a lot of injector noise while giving it intake cleaner with the rpm's at about 2000rpm and up. I'm pretty sure that they shouldn't be noisy like that, correct me if I'm wrong as I'm new to 16v motors. If they are in fact bad does anyone have a set of good injectors that they could sell me or is there a way to repair or rebuild them?
Thanks in advance for any help you can offer :)
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline mrfuelish
  • 2862
Re: Injector noise
« Reply #1 on: November 26, 2005, 05:45:38 PM »
There is a solinoid on the front of the engine that makes alot of clicking noise on mine and a few other things in there also that make noise from time to time but I don't remember hearing my injectors making any, having them cleaned would not make them quiet,there are several places that do clean them I have seen them for about fifty bucks for all four and they replace the screens in the top of them that rust out and the o rings. oh ya they will batch check them if you ask them but you cannot rebuild them you have to get new if bad,I think there around 139.0 to 169.00 each.
« Last Edit: November 26, 2005, 05:48:58 PM by mrfuelish »
Offline DirtDevil
  • 317
  • Island4x4.com
Re: Injector noise
« Reply #2 on: November 26, 2005, 09:42:51 PM »
my 8v out of an 89 has a very loud injector but only when i turn on the lights... im guessing it richens up the fuel to keep the revs or? i find it kinda weird...
Sj410 Full exo, Locked, race buckets, 5 point
85.5 LWB sami, Toy axles, locked rear, CJ/RUF, warn 8000, 33's
Re: Injector noise
« Reply #3 on: November 27, 2005, 10:24:00 AM »
That sounds more like the Idle Speed Controller, it lets more air through the bypass passage to keep the revs up.
Offline toolman21
  • 229
  • 89 Kick with 5" lift and 30's
Re: Injector noise
« Reply #4 on: November 29, 2005, 12:47:30 PM »
Mine has always done the same thing, I put a cone filter on it and now when you turn on the lights or blower fan it sounds like a midget with a rubber hammer under the hood.  I might have to go back to the stock airbox.
The idle speed does not get any faster, it just has a wierd echoish ducka ducka ducka sound .  Its actually quite annoying.
Toolman
Re: Injector noise
« Reply #5 on: November 29, 2005, 02:25:53 PM »
Its not supposed to, the Idle Speed Controller keeps it constant, without it the revs would drop. Under load it lets more air through which is the same as using just a tiny bit of throttle.
Offline biker
  • 730
Re: Injector noise
« Reply #6 on: November 29, 2005, 09:00:22 PM »
Every 89 I've seen does that.   Does anybody have any more info on the 16v injectors? :(
99 Vitara 2wd
10 Gr Vitara
Offline Ian
  • 50
    • Island Rock Crawlers
Re: Injector noise
« Reply #7 on: November 30, 2005, 08:54:34 AM »
Biker, if you need something to compare it to you can swing by and check out ours.  It is a 92 with the 16 valve.
Ian
Offline toolman21
  • 229
Re: Injector noise
« Reply #8 on: November 30, 2005, 12:12:03 PM »
Can you use an injector off a later model that might be quieter?  Never really thought about that, I just assumed they all did that.
Toolman
