INJECTOR SPRAYS CONTINIOUSLY
  • 1437 Views
Offline RBEBY
  • 21
  • BEACHIN
« on: December 09, 2003, 09:27:58 AM »
89 SIDEKICK 1.6 ,ENGINE HAD DIED, FUELPUMP RELAY  RATTLES,CHECK ENG LIGHT ON CONTINIOUS ,FUEL STARTED TO RUN OUT OF AIRCLEANER WITH KEY ON, CAN'T SELF TEST COMPUTER.
Offline kahless92
  • 22
  • Here we call it liquid sunshine!!
Re: INJECTOR SPRAYS CONTINIOUSLY
« Reply #1 on: December 09, 2003, 01:20:06 PM »
look under your dashboard on the left side  above the fuse box, you should see a switch(kinda like what you would see under a remote control car) flip the switch the other way and then test the computer, then post any codes you may pull from it. If you need instructions on pulling the codes let me know and i will post instructions
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #2 on: December 09, 2003, 04:25:42 PM »
It sounds to me you have a dead short to ground in the injector or harness. If I remember right the injector is powered (+) all the time and the computer pulses the ground (-) for the injector to release fuel. Get a wiring diagram to be sure. I had the same thing happen after a squirrel tried building a nest and chewed a couple of wires.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
« Reply #3 on: December 09, 2003, 06:21:22 PM »
87BlackSami is right about the operation of the injectors. Could be a short in the wiring loom, might be the ECU though :(
