Installing a Grand Vitara front housing questions?
  • 2411 Views
Offline Mr._NSX
  • 155
« on: August 17, 2003, 01:39:37 PM »
I just read the Mike Hagen's article about installing a front locker and was wondering if a 02 Grand Vitara Steel Front 3rd member housing is a direct bolt in replacement for the stock sidekick housing.  I plan on just taking out my current 3rd and axles and installing just the steel housing and stock 3rd, not a rear sammi like in Hagen's article.  So my qustion is, will this bolt directly in? Or will I need to machine anything?
Thanks.
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: Installing a Grand Vitara front housing questi
« Reply #1 on: August 18, 2003, 08:56:45 AM »
 Its a direct bolt in but you will need to add another bolt to plug a hole in the housing where the vaccum actuator for the GVs goes through. That sounds harder than it really is. Youll see what I mean when you get it. The only reason for swapping in the sami housing is to put a locker in.
Mike
« Last Edit: August 18, 2003, 08:58:15 AM by Mikerpm4x4 »
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #2 on: August 19, 2003, 03:27:25 AM »
Use only the housing, sell the "air diff" on ebay, as they are a COSTLY unit new.
If you can, get the steel unit from the XL7.  It has a bigger center mount boss, and the center mount is a 2pc design that won't bend like the GV/Kick mount can.
Yankee Tim
