Ok having weird issue 95 tracker won't start
  • 1084 Views
Offline twistedthrottle
« on: May 07, 2010, 02:52:08 PM »
I've had this 95 16v automatic tracker awhile. Ok story starts my wife drives the car. She told me that it is suffering from a power loss. Me being out of town had my local mech look at it. He did a full tune up. It ran a little better but not like it's suppose to. I had her take it back and he found thirteen degrees out of time. Adjusted it ran like new. Happened a week later same thing out of time and she had the timing checked 18 degrees out. Another week goes by the tracker from full power to dead in about a two mile strech. Took it in for timing belt found that it was the crank key on the timing gear. OUCH put a new crank in and now it won't start (it's real close though). (Was this a secondary problem with the tracker dieing on the final day). Timing is dead on. Built a adapter to check fuel presure it's good. 180#s of compression on all four cylinders. Nice consistant spark. I'm bout to spend a lot of money to have it diagnosed at an electrical shop. Just lookin for ideas. This thing hasn't ran in almost 2 years
Re: Ok having weird issue 95 tracker won't start
« Reply #1 on: May 07, 2010, 03:32:35 PM »
How are you checking the timing? If you put in a new crank, you had to remove the timing belt. It could be a tooth off in either direction and cause this type of starting issue. Also, the crank/cam timing on these is quite easy to get wrong due to the confusing marks on the cam and crank wheels. Try rotating your distributor all the way one direction  ( retard ) then the other ( advance) and see if it wants to start easier. Did you just pull the Crank out through the oil pan or did you disassemble the whole engine?
« Reply #2 on: May 07, 2010, 04:47:32 PM »
To be honest i'm not the one working on it. I haven't checked the timing myself. I know he had the valve cover off and should have been able to do double check it. The plugs seemed dry. But we couldn't get it to run off of a direct fuel spray through the intake. They pulled the motor. Then the cank from the oil pan. I was thinking that it died for another reason and I found the freak deal bout the crank key. I just don't know. I'll check back in with any leads.
After sitting here thinking about it i'm just going to double check everything. It has to be something simple.
« Reply #3 on: May 07, 2010, 08:31:31 PM »
I would say the crank key was the problem all along.
I'd guess the timing is probably 180* out (just firing at the correct time on 2 cylinders...so that is probably why it "real close" to starting).  Or it could be off a tooth, like BP said.
