going from 31's to 36's (PICS)
  • 7 Replies
  • 1678 Views
Offline track_this
  • 332
« on: July 18, 2006, 03:09:53 AM »
so ive had these 36" iroks brand new(still have the rubber tits on them) sitting at my house. finally decided i should keep them and put em on the tracker, test fitted them they fit ok if i want to do a 10 point turn on every corner or just drive straight. as soon as i get my brakes fixed its time to see how much will be needed to be cut with the sawzall. i might go with a 3" body lift. im in the process of figuring out my funds but im probably going to do stans toy cv swap for the front and eventually upgrade to the calmini rear axle shafts.
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Re: going from 31's to 36's (PICS)
« Reply #1 on: July 18, 2006, 03:59:42 PM »
Me thinks you may need a bit more gear to pull those bad boys.
« Reply #2 on: July 18, 2006, 06:49:49 PM »
And a little less floor board ;) ;D
Offline Maroon Monsoon
  • 876
« Reply #3 on: July 19, 2006, 12:36:41 AM »
that's wierd how it sits level with 31's in back and a 36 up front. is it just on that one side? that could be it. also, the front suspension is probably flexing a tadd so you probably have a little more room than in your test fit
good luck buddy, wicked tires
Offline track_this
  • 332
« Reply #4 on: July 19, 2006, 03:20:58 AM »
i was kinda wondering the same thing? ah well it was just a test. do you think with 5.12 gears 5speed trans and the 2lo kit i would do ok or do you think it will be a dog?
rear lockright
31" kumho m/t's
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #5 on: July 19, 2006, 11:00:33 AM »
Goodbye cv's.
1993 4-door Sidekick
4.24:1 t-case
  • 876
« Reply #6 on: July 19, 2006, 11:31:51 AM »
how's it doing with the 31's? I am going to get some kumho MT's and was wondering how you liked them
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #7 on: July 19, 2006, 08:54:29 PM »
Major Dog..  I didn't even care for the 31's with 5.12's... the 2lo kit does nothing for gearing...  but with a set of transfer case gears you could turn them.. with 5.12's it would put a LOT of stress on yokes/shafts/tc mounts... etc.. a LOT.
Hagen and his cronies use them bigguns... ask them how THEY are geared...
